Samsung Galaxy S - Android 4 problem
lemmy sixx
Stavio sam danas Android 4 na moj Galaxy S I9000.U pocetku je sve bilo ok,medjutim nakon vracanja backupa sa Titaniumom,sve je pobrljavilo.Gomila aplikacija nece da radi,kontakti ne postoje,cak ne mogu ni slati poruke u postojecim konverzacijama...mogu ih slati samo ako zapocnem novu konverzaciju.Svaki puta izbaci poruku "Unfortunately,... has stopped".Verovatno je backup nesto pojebao.
Ima neko resenje?
Odradio sam factory reset,sada radi.Dakle sve mi sjebao backup.Probacu samo user i system files da stavim,bez aplikacija.
edit:ni to ne vredi...na kraju sam samo kontakte i poruke vracao,i *****.Opet zakucava...sada samo u porukama.
Titanium backup ne radi bas najsrecnije sa ICS. Nemam iskustva o tome ali su bili neke vesti po netu da restore nece raditi.
TB radi dobro sa ICS, ali covece gde ces sistemske fajlove da prebacujes si lud? To ti je kao kad bi u juga gurao meckin motor.
Aplikacije mogu, sistemske nikad nisu mogle sto se tice razlicitih verzija androida.
Мени титаниум ради одлично са апликацијама.
Migrate system data - Cekirano
Restore missing apps + data
After restoring your apps' settings, now most of your stuff should be good. Now it is time to restore your system settings. Run The batch Restore missing apps + system data as follows: Press uncheck all. next, scroll through the list - anything that syncs with Google account (contacts, GMail, Calendar, etc.) Do not check. You're looking for items that are in green - those are system items that can be safely restored, but you don't want to do all of the green ones - kinda taking a big chance. A few good ones are the following:
[BOOKMARKS] Browser
[CONTACTS/CALLS] Contacts Storage
[SMS/MMS/APN] Dialer Storage
[PLAYLISTS] Media Storage
[SMS/MMS PREFS] Messaging
Accounts
Application Widgets
[USER DICT] com.android.providers.userdictionary <-- (may not be there in your phone)
[VOICEMAIL] Dialer
All of the rest SHOULD be synced to and restored from your Google account automatically.
DO NOT RESTORE THE ONES IN RED AT ALL!
The ones in gray are application specific, so you can pick and choose any of those as well if you have the application back but its settings are still not there.
Kod mene je vracanje app isto pravilo probleme i to zbog jedne aplikacije (Kaiten email) jer je sa njom vracao i sve email-ove (par stotina MB doticnih). Odmah je krenuo da prijavljuje Low storage space i da FC sve od reda.
Ostale aplikacije je normalno vracao.
