Da li neko ima ovaj tv? Kakva su iskustva? Zanima me da li je 3d televizorima normalna slika kada se gledaju 2d kanali? Da li vredi za njega dati 750e?
Samsung televizor LED UE-40D6500
Samsung 3D televizor LED UE-40D6500 Smart TV 400Hz
Clear Motion RateDijagonala ekrana: 40"/101.6cm
Format ekrana: 16:9Rezolucija: 1920 x 1080Dinamički kontrast: Mega Contrast
Picture Engine: 3D HyperReal EngineWide Color Enhancer PlusDisplej: Ultra Clear PanelLED Backlighting Technology Edge LEDAudio: Dolby: Dolby Digital Plus / Dolby PulseSRS: SRS TheaterSound HDdts 2.0 + Digitalni izlaz
Zvučni izlaz (RMS): 15W x 2Smart TV: Samsung SMART TVSmart HubSearch AllSocial TVSamsung AppsSkype on
Samsung TVWeb BrowserKarakteristike:3D konverter
3D Sound (TV)Allshare (Powered by DLNA)Smart Phone Remote supportWireless LAN ugrađeniOne Foot ConnectionPersonal Video Recorder Ready (Extended PVR)Time ShiftConnectShare
(USB2.0): filmBD WiseAnynet+ (HDMI-CEC)HDMI 1.4 3D Auto SettingHDMI 1.4 A / Return Ch. SupportInstaPort S (HDMI quick switch)Channel List USB - CloneAutomatsko pretrazivanje kanala
EPGTeletext (TTX)OSD LanguageAuto Volume LevelerAutomatsko isključivanjeSat & On/Off
TimerSleep TimerGame ModePicture-In-Picture: 1 tuner PIPSistem: HD tuner ugrađeniDTV Reception(DVB-T/T2/C/S2): DVB-T/C/S2CI+: CI+Priključci:
HDMI: 4
USB: 3
Komponentni ulaz (Y/Pb/Pr): 1
Kompozitni ulaz (AV): 1
(Common Use for Component Y)Digital Audio izlaz (Optički): 1PC ulaz
(D-sub): 1CI Slot: 1Scart: 1RF ulaz
(Terrestrial/Cable Input): 1RF ulaz (Satellite input): 1Slusalice: 1PC
Audio ulaz (Mini Jack): 1
DVI Audio ulaz (Mini Jack): 1
(Common Use for PC Audio)Ethernet (LAN): 1
Potrosnja u radu (max)/ stand-by: 160W / ispod 0.1WBoja: crna
Dimenzije bez postolja (SxVxD): 933.07 x 72.26 x 2.99 cm /
Dimenzije sa potoljem (SxVxD): 933.07 x 80.54 x 30.5 cm /
Tezina sa postoljem: 21.9 kg
Tezina bez postolja: 17.2 kg
Tezina pakovanja: 12,6 kg
HDMI: 4
USB: 3
