riser kabl za grafu 3.0 na 4.0 sistem
oogabooga
nesto sam se zamlacivao da stavim produzni riser za grafu i da stoji uspravno, i stigne mi od mog kucista TT oridjidji kabl konacno, kad ono ima sta da vidim:
Thermaltake PCI-E 3.0 x16 Riser Cable
PCI-E 3.0 X16, TT Gaming Riser Cable PCI-E 3.0 X16, 200mm,
on je 3.0, a sve mi je u kucistu sad 4.0.
mogu li neku zbrku napraviti ako ga stavim, mislim na to da nesto ubrljavi i pocne da ne radi komp kako treba?
hvala
Može biti problem sa stabilnošću, preporuka je promeniti u biosu na 3.0 info sa AMD sajta:
...here may be some system stability issues when used in combination with PCIe Gen 4.0 devices...Change PCIe Slot Configuration setting – The PCIe Slot Configuration option is found in the system BIOS. Change its current setting to Gen 3.0 then save and exit the BIOS. After the system reboots check whether the stability issues persist.
Isto sa Asus sajta:
Disclaimer: This product is only compatible for devices that support the PCI-E 3.0 specification. If you use this product with a motherboard that supports PCI-E 4.0, please enter into BIOS option and select PCI-E 3.0 before installation.
Na ovom videu je testerio kablove i imao je probleme i isto je promenio na 3.0:
valjda sam dobro odradio, u biosu pod pci-e 16x, mogao sam da biram AUTO, ili gen1, 2,3 i 4, stavio sam na gen 3, valjda je to 3.0?
