Return to Castle Wolfenstein benchmark
Marti Misterija
VIP član
Skinuh checkpoint bench. Gde da ga raspakujem, kako da ga pokrenem?
Need help. Over and out(D)
Naviguj do Main direktorijuma (obicno C:\Program FIles\Return to Castle Wolfenstein) i u istom napravi direktorijum DEMOS. Nakon toga, ubacis checkpoint.dm_57 iz skinute arhive u DEMOS direktorijum i startujes WolfMP.exe (iz nekog razloga, u single player varijanti demoi nece da se pustaju?!?!). Kad se igra startuje, pritisni "~" i upisi:
TIMEDEMO 1 (ENTER)
DEMO CHECKPOINT (ENTER)
Sacekas da se izvrti demo i nakon toga pritisnes opet "~" i videces rezultat meren u fps.
Evo i mojih rezultata...
- Cely 566@850Mhz
- 256MB CL2
- Prolink MX400 64MB SDR 210/225
- Maxtor D740X 6L 40GB
- Creative 128PCI
- Win98SE
- Detonator 22.80
Rezultat - High Quality: 45.4FPS
U Games Options stoji ovako:
- Wall Mark Lifetime: Normal
- Ejecting Brass: Med
- Dynamic Lights: YES
- Low Quality Sky: No
- Sync Every Frame: No
- Corona Dist: Normal
- Particles: Yes
- In Game Video: Yes
Ovo pisem jer doticna podesavanja uticu na frame rate (valjda :) )...
Pozdrav :)
Hvala lepo
lepo si se potrudi, hvala na savetima, postovacu veceras svoje rezultate, ako nekoga interesuju (ATI 7500;)
RTCW rezultati
Evo mojih rezultata.
- TBird 1133Mhz
- 256 mb CL3
- Epox KTA3L+
- ATI 7500 OEM build/powered by ATI 270/230Mhz gpu/memorija
- Maxtor D7406L 40Gb
- Win98SE
- ATI drivers 7189
System setings:
- 1024x768 32bit
- lightning: high
- geometric detail: high
- texture detail: high
- texture quality: 32bit
- texture filter: bilinear
- compress textures: yes
Game options:(isto kao i kod tebe)
- Particles: Yes
Rezultati:
640x480 - 52.9 fps
800x600 - 52.8 fps
1024x768 - 51.9 fps
1280x1024 - 46.1 fps
Interesantno, zar ne!
Hvala Omnik u svakom slucaju:wave; (D)
Re: RTCW rezultati
Ocigledno los demo... kod mene je u High Quality samo 1600x1200x32Bit ima 20fps dok je u 1280x1024x32bit sasvim igriv - 35 fps !!! RtCW sam u singleplay-u nije igriv u toj rezoluciji sa tim podesavanjima - dakle, smesno ctp;
Re: RTCW rezultati
Marti Misterija je napisao(la):
- TBird 1133Mhz
- 256 mb CL3
- Epox KTA3L+
- Win98SE
- ATI drivers 7189
System setings:
- 1024x768 32bit
- lightning: high
- Particles: Yes
Rezultati:
640x480 - 52.9 fps
800x600 - 52.8 fps
1024x768 - 51.9 fps
Nesto su mnogo blizu vrednosti za razne rezolucije. To obicno znaci da treba jaci procesor, sto je apsurdno, u ovom slucaju. Verovatno se sa GTS-om dobiju bolji rezultati u nizim rezolucijama, dok bi trebalo da su slicni u visim.
Ljudi a gde ja da nadjem taj checkpoint bench.
E blago vama kad mozete da igrate RTCW,meni na Athlon 1,2 GHz,256 DDR,Epox 8 KHA,Ati Radeon 32 DDR ucitavala se oko 3,5 sata samo da krene(stavio sam sve na low)
Ma najozbiljnije,ne znam koji mu je
ICE je napisao(la):
Radeon mu je :( Naravno vi mozete misliti da se ja zezam ili da nemam pojma kad govorim o grafickim kartama za igre ali upravo zbog takvih problema koji su potpuno nasumicni se svakom gameru isplati kupovina nekog GF-a...
Ma daj bre, ne pricaj gluposti filipenko. Imao sam LE skoro 3 meseca, SDR dve nedelje i igrao sam sa istima vecinu komercijalnih igara. Bilo je brljanja ali textura ili neke igre nisu radile uopste (sto je resavano patchevima)... nikad nisam cuo za takav problem sa ucitavanjem zbog neke graficke. Ili je u pitanju spor hard-disk (kome defragmentacija nikad nije radjena), zeznut registry itd. Gotovo sam siguran da bi posle reinstalacije windowsa problem nestao (ako ne resi, onda je neki hardver ne ispravan, ili bar ima konflikta...). Ma najbolje je odmah format i sve ponovo.
pa disk sam defragmentisao,proverao sam i nema nikakvih konflikata.Da kazem da ostale igre odlicno rade tako da nemam pojma u cemu je problem
filipenko je napisao(la):
Tesko da mu je Radeon. Coveku se igra dugo ucitava.
