Reinstalacija sistema na Qtek 9100
kovica
Ortak je sjebao navedeni Qtek raznim programima i *******cijama i sad ne moze da udje ni u jedan settings meni niti ista. Jel postoji neka mogucnost instalacije operativnog sistema? Ako ima ne bi bilo zgoreg i malo i kratko objasnjenje kako, gde i zasto.
Hvala unapred
Edit: sad sam video da ovaj topic moze i trebalo bi da bude na drugom mestu, neka admini slobodno pomere topic na adekvatnu lokaciju :)
moze da uradi hard reset. sve se brise i sistem se vraca u fabricko stanje.
How to hard reset the Qtek 9100
NOTE – Hard resetting your PDA will return it to a factory default state and all user information will be erased.
1. Press the Comm Manager and Voice Command buttons simultaneously and keep them pressed
2. Using the stylus, press the reset button on the right hand side of the unit next to the infrared port and release (still keeping the two buttons pressed)
3. A message will be displayed on the screen: ”Press Send to restore factory default, other keys to quit”. Press the green “call”, or “send” button.
The unit will now undergo a hard reset.
