razlike u CF
Kapetan DZo
da li se osete razlike u CF ako je 8x ili 16x?Ili je to cisto akademska razlika
neznam tacno, ali mislim da nije velika razlika, ali opet o ovome stvarno malo znam
Nacuo samda seoseti samo u sintetickim testovima ali za igrice da je nemoguce primetiti.Uzeo sam P45 pa se sad razmisljam da li da uzmem dve 4870 ili jednu 4870X2 ili GF280
Kljucno pitanje je sta ce ti 2x4870 kad imas 22" monitor ?
Jedna 4870 ima da ti tera svaku igru tecno, ne bacaj pare...
This is really a very interesting article and is something people need to be taking note of. The first thing you need to be checking is if you're reading a review where Crossfire is being tested. Make sure that the board there using is a x16 / x16 motherboard. The results really do speak for themselves and it’s clear that there is a performance difference between a x16 / x16 configuration which the X48 offers, and the x8/x8 one on the P45.
If you’re really thinking about going down the Crossfire path, we would be highly recommending that you spend the extra money to go to an X38 or X48 based motherboard over the P45. Of course, if you’re not then it doesn’t really matter. With one card the P45 runs at x16, which is exactly what you want.
Ceo test - http://www.tweaktown.com/articles/1472/1/intel_p45_vs_x48_crossfire_performance/index.html
veoma zanimljiv tekst, izgleda da mi je vise isplativije uzeti jednu jacu kartu i dobro kloknuti procesor koji bi je ispratio i naravno dosta memorije.
