Tplink WR-743ND je primer mešovitog rutera. Tj. možete da birate kako će da radi izmedju 5 modova: Client Router / Router / Repeater / Bridge with AP / Client
Client Router - In this mode, the device enables multi-users to share Internet from WISP. The LAN port devices share the same IP from WISP through Wireless port. While connecting to TL-WR743ND 150Mbps Wireless AP/Client Router WISP, the Wireless port works as a WAN port at Client Router mode. The Ethernet port acts as a LAN port.
Router - In this mode, the device enables multi-users to share Internet via ADSL/Cable Modem. The wireless port share the same IP to ISP through Ethernet WAN port. The Wireless port acts the same as a LAN port while at Router mode.
Repeater - In this mode, the AP will relays data to an associated root AP. AP function is enabled meanwhile. The wireless repeater relays signal between its stations and the root AP for greater wireless range.
Bridge with AP - In this mode, the device bridge to another AP.
Client - In this mode, the device will act as a wireless station to enable wired host(s) to access AP.
E sad
po uputstvu ovaj ruter može da se zakači na wisp kao client i a u isto vreme bude AP za lokalnu mrežu. Client Routeri Bridge with AP modovi. Samo u prvo slučaju rutira a u drugom je samo most iliti bridge.
Da li ovo postiže nekim virtualnim AP-om ili ima 2 odvojena wifi porta u sebi ne bih znao? Kako neka kartica kad je u client modu može da bude i u AP modu istovremeno i to pod drugim SSID-om?
