Racunar pišti 1 dugi i 3 kratka?
mdshare
Izvadio sam grafičku kartu da očistim od prašine, vratio računar sad pišti 1 dugi i 3 kratka. I nakon toga da normalno sliku i sve radi, ali nakon svakog paljenje racunra isto pišti.
PS: Testirao sam memoriju, vadio iz slotova vraćao, takođe i grafiku.
Proveri kartu opet,izvadi,vrati..da legne lepo.Proveri konektore iste.
Probaj i cmos.
MAXIMUS IV EXTREME-Z
Beep Code for Asus MB
Description
1 (short)
DRAM refresh failure.
2 (short)
Parity circuit failure.
3 (short)
Base 64 K RAM failure. Try removing any added memory, or reseat the installed memory sticks.
4 (short)
System timer failure.
5 (short)
Process failure.
6 (short)
Keyboard controller Gate A20 error. Check if your keyboard is connected to the proper port.
7 (short)
Virtual mode exception error.
8 (short)
Display memory Read/Write test failure.
9 (short)
ROM BIOS checksum failure.
10 (short)
CMOS battery error. Replace the CMOS battery to fix this.
11 (short)
Cache memory error.
1 (long) + 3 (short)
Conventional or Extended memory failure. Remove added memory, or reseat the installed memory sticks.
1 (long) + 8 (short)
Display/Retrace test failed.
Two-tone siren
Low CPU fan speed, or voltage level issue.
@mdshare : iz uputstva za tu matičnu ploču:
One short beep
VGA detected Quick boot set to disabled No keyboard detected
One continuous beep followed by two short beeps then a pause (repeated)
No memory detected
One continuous beep followed by three short beeps
No VGA detected
One continuous beep followed by four short beeps
Hardware component failure
Izduvati sve pažljivo od prašine, ploču, konektore, hladnjake, ventilatore.
Testirao sam memoriju, prosla test. Testirao sam grafiku sa Furkmarkom i 3d markom normalno sve. Igrao i igrice bez problema.
Čoveče čitaj malo, @Vladarko ti je bukvalno sažvakao informaciju za tvoju matičnu...
Jedan dugi pisak i tri kratka problem sa VGA...
Ako tebi grafika baca sliku, to je onda ili neka zabuna, ili si malo oštetio one zlatne pinove na grafičkoj kad si je vadio pa je kontakt slabiji pa to zbunjuje matičnu...
