Program za merenje temperature?
Toshiba
Trebao bi mi neki dobar ali jednostavan program za merenju temperature CPU-a. Kad kazem jednostavan mislim na to da ne bude u okviru nekog programa kao npr. Everestam, nego da mi samo kao notification ikonica pokazuje temperaturu.
Ima li takav neki program?
Ja koristim HardwareMonitorPro i extra sam zadovoljan. Mali program a daje mnogo. Osim svih temperatura, meri i napone i brzine okretanja coolera.
fade je napisao(la):
ja imam asus pc probe odlican je ,moze da radi i na drugim plocama ,mada sam probao sam na jendoj ,inace bash je to sto ti trazish
Meni se dešavalo da mi comp secka dok je podignut Asus PC Probe (na svakih par sekundi, u jednakim intervalima, pretpostavljam da je u momentima kad vrši očitavanje vrednosti), npr. dok ide DivX se najlakše uoči. Je li imao još neko ovakvih problema?
Bilo je već o ovome >>> KLIK
Ma Asus PC Probe je kurton od programa koji ne daje tacne podatke.
Probaj covece SpeedFan i bices zadovoljan. ;)
@vectorman
Gde si pronasao taj HardwareMonitorPro?
Daj neki link.
Pronašao kod sebe na hardu :D
Napiši mi svoj mail na pm pa ću ti poslati programčić.
If you are looking for a tool that can change your computer's fan speeds, that can read your hard disk temperature and S.M.A.R.T. status, that can read temperatures, voltages and fan speeds and much more, then you came to the right place. SpeedFan works fine with Windows 9x, ME, NT, 2000, 2003 and Windows XP. And this is absolutely for free :)
Download
The latest version is SpeedFan 4.24. Some tools (like Norton Internet Security or Zone Alarm) may interfere with the download process. Basically, the REFERER field must be properly sent to SpeedFan's web server. Download won't work if any tool blocks it. For WebMasters: if you do not want to mirror the download locally to your website, please link to http://www.almico.com/speedfan.php and not to the direct download as it won't work. Thank you for your cooperation.
What is SpeedFan
SpeedFan is a freeware program that monitors voltages, fan speeds and temperatures in computers with hardware monitor chips. SpeedFan can even access S.M.A.R.T. info for those hard disks that support this feature and show hard disk temperatures too, if supported. SpeedFan supports SCSI drives too. SpeedFan can even change the FSB on some hardware (but this should be considered a bonus feature). At the lowest level, SpeedFan is an hardware monitor software that can access temperature sensors, but its main feature is that it can change fan speeds (depending on the capabilities of your sensor chip and your hardware) according to the temperatures inside your pc, thus reducing noise and power consumption. SpeedFan can help you to build your own silent pc.
STA SAD DA RADIM!!!!!!!!
Pa kako da ga skinem kad nece da download.stalno me nesto cima iz prozora u prozor da li mi trazi neke parametre ne znam?p4p 800 se/gd. p4 2.4,koji sam mentol :wall: :wall: :crash: :crash: :crash: :wall: :wall:
MBProbe
