Ljudi, treba mi pomoc
Kupio sam nov HD, napravio particije i krenuo sa instaliranjem. Kad sam instalirao sve driver-e krenuo sam sa programima. Prvo sam instalirao Office 2000, pa onda CorelDraw 10 (jel su mi hitno trebali). Kad sam obavio to sto sam trebao u Corelu nastavio sam sa instalacijom jos nekih programa. Kada sam malo kasnije ponovo hteo da startujem COrel pri ucitavanju se pojavila sledeca poruka:
Prozorcic, u zaglavlju (title-u) pise:
CorelDraw 10 Condition #5000-DRAW-3961
A dole:
Unexpected condition encountered. Please refer to the Technical Support Help.
I dugme OK, naravno.
Kad kliknem na ok pojavi se ponovo prozorcic, u zaglavlju pise:
Microsoft Visual C++ Runtime Library
a dole:
Runtime error!
Program: C:\PROGRAM FILES\COREL\GRAPHICS10\PROGRAMS\CORELDRW.EXE
abnormal termination
(i opet dugme OK)
kad i to kliknem pojavi se onaj dobro poznati prozor "This program has performed an illigal opetartion i dugmad colse i details>>
na details pise:
ORELDRW caused an invalid page fault in
module CORELDRW100.DLL at 0167:60950809.
Registers:
EAX=00000000 CS=0167 EIP=60950809 EFLGS=00210202
EBX=bff55591 SS=016f ESP=0063fc04 EBP=00000000
ECX=0063f62c DS=016f ESI=0063f4c4 FS=125f
EDX=00000450 ES=016f EDI=00000004 GS=0000
Bytes at CS:EIP:
ff 52 38 8b 8e 14 01 00 00 3b cd 74 06 8b 01 6a
Stack dump:
00000001 61585888 0063fc50 60760000 00b42f68 bff7dcc4 00000000 00b42fb8 5f401018 5f401018 00000004 00000001 0063fe28 61227ac0 ffffffff 611df853
Ne vredi ni reinstalacija, ni brisanje uninstall pa install, nista...
Ako neko zna u cemu je problem, javite, molim vas jer mi je COrel bas potreban.
pozdrav i hvala unapred
A dole:
a dole:
Runtime error!
(i opet dugme OK)
na details pise:
Registers:
Bytes at CS:EIP:
Stack dump:
