Problem UT2003
  • Začetnik teme Začetnik teme mneo
mneo
UT2003 Setup Build [2002.05.31.18.31]
OS: Windows XP 5.1 (Build: 2600)
CPU: AuthenticAMD PentiumPro-class processor @ 936 MHz with 255MB RAM
Video: No Video
Nije mi jasno zasto prijavljuje : "Video: No Video"
Graficka je Gainward GF4 MX440
Installer file not found: ..\Textures\AbaddonArchitecture-epic.utx (The system cannot find the file specified.)
The source media may be bad. If installing from a CD, try cleaning the CD to remove any dirt, check your CD drive, and try again.
ALI ovog doticnog fajla " ima" u texturama "direktorijumu" !!??
Sta mislite ?
Ja nemam UT ali ako ima crack, moze biti i do njega..probaj opet sa instalacijom, promenio crack, probaj drugi disk, probaj te diskove na drugoj masini (grafickoj)
