Problem sa Yahoo-om!
zverkons
Kada se ulogujem na yahoo-mail,i kada pokusam da si pogledam postu on mi izbaci ovo:
Your login session has expired.
Why does my session expire?
Login sessions expire for two reasons.
For your security, your Yahoo! Mail session expires a maximum of eight hours after you have logged in. If you have chosen in your Yahoo! User Information to be prompted for a password more frequently than every eight hours, your session will expire after the specified amount of time.
If you do not accept the cookies set on login or your computer is not configured to accept cookies, your session will expire almost immediately. We use cookies (small pieces of site information) to assist us in user authentication and in saving configuration information. Cookies are required for Yahoo! Mail.
If you see this message immediately after logging in, you should check the following:
Check to see that your computer system time is accurate. Cookies are time sensitive and may not work if your computer date is incorrect by a large amount.
Make sure that your browser is configured to accept cookies or that you agree to accept cookies during the login process.
Turn off any third party programs or control panels that automatically reject cookies.
Vidim da je neki problem sa cookiima ali ne znam sta,ako neko moze da mi pomogne?
Pa u IE, pod Tools/Internet Option/Privacy vidi da li ti je slider na Medium, odnosno postavi ako nije.
