Problem sa WD HDD
saigic
Juce dok sam gledao nesto na internetu cuo sam da je u HDD nesto skljocnulo a nakon toga 3 od 5 particija su mi bile nedostupne. Resetovao sam kompjuter 2-3 puta, podizanje sistema je islo malo sporije ali se nista nije promenilo dok ga nisam skroz ugasio. Nakon toga je sve bilo normalno, svi podaci na disku prisutni. Pustio sam WD Data Lifeguard i evo rezultata testa
Test Option: QUICK TEST
Model Number: WDC WD1600AAJS-00B4A0
Unit Serial Number: WD-WMAT20321374
Firmware Number: 01.03A01
Capacity: 160.04 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 06-Quick Test on drive 1 did not complete! Status code = 07 (Failed read test element), Failure Checkpoint = 97 (Unknown Test) SMART self-test did not complete on drive 1!
Test Time: 16:31:10, May 05, 2012
Test Option: EXTENDED TEST
Capacity: 160.04 GB
SMART Status: PASS
Test Result: FAIL
Test Error Code: 08-Error was detected while repairing bad sectors.
Test Time: 17:01:29, May 05, 2012
Sta dalje raditi, da li je disk pouzdan ili sledi zamena?
