Problem sa surfovanjem
  • Začetnik teme Začetnik teme Celt
Celt
Nakon uspesno usposavljene veze sa provajderom preko Dial-up konekcije iz IE explorera,znaci vreme tece,ikonica koja pokazuje status konekcije je prisutna,pokazuje brzinu itd.,ali pri pokusaju pokretanja BILO KOG SAJTA pojavljuje se sledeca poruka:
____________________________________________________________
The page cannot be displayed
The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings.
Please try the following:
Click the Refresh button, or try again later.
If you typed the page address in the Address bar, make sure that it is spelled correctly.
To check your connection settings, click the Tools menu, and then click Internet Options. On the Connections tab, click Settings. The settings should match those provided by your local area network (LAN) administrator or Internet service provider (ISP).
If your Network Administrator has enabled it, Microsoft Windows can examine your network and automatically discover network connection settings.
If you would like Windows to try and discover them,
click Detect Network Settings
Some sites require 128-bit connection security. Click the Help menu and then click About Internet Explorer to determine what strength security you have installed.
If you are trying to reach a secure site, make sure your Security settings can support it. Click the Tools menu, and then click Internet Options. On the Advanced tab, scroll to the Security section and check settings for SSL 2.0, SSL 3.0, TLS 1.0, PCT 1.0.
Click the Back button to try another link.
Cannot find server or DNS Error
Internet Explorer
Sta je uzrok ovome,inace OS je WIN98?
idi u command prompt pa pokusaj ping tvoj rpovajder, znaci ako si na beotelu recimo kucaj ping beotel.yu
cisto da vidim jel ti radi link ka provajderu ili je nesto pogresno setovano.
Uradjeno poruka sledeca:
F:\>ping beotel.yu
Ping request could not find host beotel.yu. Please check the name and try again.
F:\>
Sta dalje?
Proveri da li si dobro podesio dial-up konekciju po uputsvu provider -a, pogotovo deo o DNS server -u.
Sve je vec podeseno po uputstvu, ali ne vredi
Meni je za tu komandu upravo rekao:
unknown host beotel.yu
A protok mi je proteklih sat vremena izmedju 6.5 i 7.5kb 🙂
Mozda se zbog zagusenja veze zbunio?
