bansek
Od pre nekih 20-ak dana ne ucitava nista!!!!
Kada ukucam adress bar-u npr. www.google.com, posle rifresha ostane samo http:/// (sa tri crte) i poruka:
"The address is not valid
Most likely causes:
There might be a typing error in the address.
If you clicked on a link, it may be out of date.
What you can try:
Retype the address.
Go back to the previous page. "
Ako ukucam http://www.google.com, dobijam poruku:
"Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
What you can try:
Diagnose Connection Problems
More information"
Internet konekcija je OK, Opera ucitava sajtove a IE ne....
Dal' je virus ili neko podesavanje????
Most likely causes:
What you can try:
Retype the address.
Most likely causes:
What you can try:
More information"
