Problem sa glasnocom slusalica
Denis98
Poštovan
Kupio sam nove HyperX Cloud Alpha sluske, zvuk je perfektan, zadovoljan sam, ali problem kad pricam sa drustvom na discordu i recimo pustim muziku, oni je cuju preglasno.
Pokusavao sam na razne nacine da regulisem to, ali ne vredi. Smanjim sens, opet isto. Reinstalirao sam drajvere, nista, sistem sam srusio, i dalje nista.
Da li neko ima resenje za ovo ?
pustiš muziku gde? na nekom uređaju sa svojim ozvučenjem pa mikrofon to hvata?
valjda na slusalicama, ne bi trebalo da mic hvata zvuk iz slusalica
Ne. Pustim na YT neku pesmu, video, nebitno i pricam na discordu sa drustvom, bukvalno sve cuju. Nista oko mene se ne cuje, osim zvuka iz slusalica...
Ne brate. Sve je iskljuceno, osim slusalica, Znaci jedino se iz njih zvuk emituje, iz nekog razloga mikrofon je jako osetljiv. Probao sam da smanjim sensitivity, ali nista ?
My friend had a similar issue with his HyperX headset, and here's how we fixed it:
We used the Realtek Audio Console app, which is often available if you have a Gigabyte motherboard. If you don’t already have it installed, you can download it from your motherboard manufacturer’s website under the audio driver section.
To check if you already have the app:
  1. Use the Windows search bar and type: Realtek Audio Console.
If you find it and it's the Gigabyte Realtek version, follow these steps:
  1. Open the Realtek Audio Console.
  2. Go to the Microphone section.
  3. Enable the option: "AEC (Acoustic Echo Cancellation) removes the acoustic echo coupled into the microphones from the loudspeaker output through air."
After enabling this feature, the issue was resolved for us. Hopefully, this works for you too!
ili
I had similar problem, solved by switching recording device to "Separate all input jacks as independent input devices" in Realtek HD Audio Manager.
Ovako nešto? Ako ne - reklamacija.
ili
Imas pivo od mene :)
Hvala ti, sad je sve okej.
Pisao sam i po reditu, citao ostale postove, ali nista...
