Problem sa c++2010
nikola123
Cenjen
Evo ovako vecina igara koju pokusavam da pokrenem izbaci mi da MSVCR100.dll ne moze da se nadje na mom kompjuteru. I googlao sam i nasao da je resenje da se instailra c++2010. Medjutim evo sta on kaze. I da instalirao sam i predhodne verzije c++. One se normalno instaliraju samo ova nece. Takodje i dx 2010 nece da se instalira...
    20.2 KB · Pregleda: 51
    41.3 KB · Pregleda: 450
NIsta se ne desava izvinjavam se zaboravio sam da kazem da je win 7 u pitanju 64 bit...
Okači taj fajl negde, teško da neko može da ga otvori sa tvog diska. :)
OS Version = 6.1.7600, Platform 2
OS Description = Windows 7 - x64 Ultimate Edition
CommandLine = d:\e2882208174d782d446d0d\Setup.exe
TimeZone = Central Europe Standard Time
Initial LCID = 1033
Using Simultaneous Download and Install mechanism
Operation: Installing
Package Name = Microsoft Visual C++ 2010 x64 Redistributable Setup
Package Version = 10.0.40219
User Experience Data Collection Policy: UserControlled
Number of applicable items: 3
Possible transient lock. WinVerifyTrust failed with error: 2148204800
d:\e2882208174d782d446d0d\vc_red.cab - Signature verification for file vc_red.cab (d:\e2882208174d782d446d0d\vc_red.cab) failed with error 0x800b0100 (No signature was present in the subject.)
No FileHash provided. Cannot perform FileHash verification for vc_red.cab
File vc_red.cab (d:\e2882208174d782d446d0d\vc_red.cab), failed authentication. (Error = -2146762496). It is recommended that you delete this file and retry setup again.
Final Result: Installation failed with error code: (0x800B010B), "Generic trust failure. " (Elapsed time: 0 00:00:05).
Sry mislio sam da moze onako...
To je ta greška za koju sam ti dao link (ceo članak: http://support.microsoft.com/kb/956702).
Probaj ručno:
To fix this, register the Softpub.dll, Wintrust.dll, Initpki.dll, and Mssip32.dll files. To register these files, follow these steps:
Click Start, click Run, type cmd, and then click OK.
At the command prompt, type regsvr32 Softpub.dll /s and then press ENTER.
At the command prompt, type regsvr32 Wintrust.dll /s and then press ENTER.
At the command prompt, type regsvr32 Initpki.dll /s and then press ENTER.
At the command prompt, type regsvr32 Mssip32.dll /s and then press ENTER.
I za svaki slučaj skini ponovo VC++ redist. paket:
http://www.microsoft.com/download/en/details.aspx?id=13523
Hvala ti na trudu i na pomoci ali izgleda da ce morati da se radi win7 na novo... Sry na smetnji evo sta sada izbaci kada probam da upisem rucno.
    23.4 KB · Pregleda: 44
Nedostaje ti razmak između dll i /s. Ali pošto je to samo switch za silent mod i ne treba ti.
Kucaj samo:
Kod:
Ne vredi prihvati ova prva dva a na trecem izbaci ovu predhodnu poruku. Isto sve ja se vec bakcem sa ovim ima 20 dana a za to vreme sam mogao reinstalirati win7 i zavrsiti posao a i maltretiram druge ljude...
    23.1 KB · Pregleda: 35
Kao da nemaš taj dll. Pretraži disk da vidiš da li ga negde ima (initpki.dll).
Takođe probaj:
Kod:
sfc /scannow
Možda ti vrati dll-ove koji nedostaju. Posle toga pokušaj ponovo da ih registruješ sa regsvr32.
Pa dobro, reinstalacija uvek ostaje kao poslednje rešenje, ali što bi sve instalirao ponovo ako može relativno lako da se reši?
Pokusao ovaj scan pretrazio a ovog dll nema. I dalje samo on nedostaje.Necu vise da te mucim brate hvala ti sto si trosio vreme a ja cu nanovo install...
Moja greška, ne treba ni da imaš taj dll, to piše u delu za XP i 2003-ku.
