E ovako.Imao sam plocu ga g31 s2c i trenutno imam proc e6750 core 2 duo.Proc je dosta zahvalan,tera ono sto meni treba.Jedina mana je sto se malo greje.E sada,plocu sam zamenio plocom p31 ds3l.Problem je u tome sto sam nasao neki tutorial kako overclockovati iako sam to znao otprilike.Uradio sam po njemu.Dosta puta sam restartovao komp i vadio bateriju.Bateriju sam zamenio novom.Imam problem kada odradim load default biosa,fsb mnozilac ne mogu da namestim na x8 samo na x6.Ne znam iz kog razloga.Dosta puta sam probao na razne nacine medjutim nista.Ovo je tutorial koji sam nasaao:
I used this guide to overclock
1. Make sure that you have the latest chipset drivers and flash the board to the most recent bios version
2. On the main bios screen press Ctrl+F1 to open the advanced options within the menus
3. In the Advanced Bios Features Menu, Disable all of the following: CPU Enhanced Halt (C1E), CPU Thermal Monitor 2(TM2), CPU EIST Function
4. In the PC Health Status menu, set the FAN Speed Control Method to "Legacy" & FAN Speed Control Mode to "PWM" to maintain highest speed
5. Go into the MB Intelligent Tweaker (MIT) menu at the bottom of the page, set the System voltage control to "Manual"
6. These boards have a default VDIMM of 1.8v, set the VDIMM to co-ordinate with your ram. The Geil I have is specced as 2.1v so I have mine set to +0.3v
7. Set the MCH Voltage to +0.1v
8. Set the FSB Voltage to +0.1v
9. Set the VCORE to 1.45v - Please be aware that this will increase temps!
10. Set the CPU Host Clock Control to "Enable"
11. Set the System Memory Multiplier to "2x"
12. You're set to go, just increase the System bus Frequency to Overclock
13. I would reccommend that you use Intels TAT to monitor temps
Medjutim,u advanced bios postoje stavke koje imaju tri oznake cpu jedna ispod druge ne znam tacno kako se zovu,kada ih disabled onda mnozilac mogu da povecam na x8 i da overclockujem procesor,cak idem i do 3.6ghz,medjutim tada problem nastaje,pes mi onda jako baguje i imam problem sa kompom jako koci,kada opet odradim load default bios-a sve se vrati na staro meni je fsb 333mhz i mnozilac x6 ispadne oko 2ghz i meni tada sve radi kako treba,ali radi na 2ghz,a ja ispod 3 ne stavljam.Ko je razumeo sta sam hteo da kazem,neka me savetuje sta da radim,ili ako neko zna da odradi bios flash da mi pomogne da odradimo,ja stvarno ne znam sta da radim.ALi znam da sam veliki baksuz,kad god uzmem neku drugu komponentu sve u djavola.Hvala puno ko god da je procitao ovaj post.
(INACE PRE NEGO STO JE OVO POCELO DA MI SE DESAVA DIZAO SAM PROC NA OKRUGLO 4GHZ RADIO JE STABILO,GREJAO SE DO 70C DOK SAM IGRAO PES NPR...POSLE SAM GA VRATIO NA 3.2GHZ)
