Problem pri instalaciji Adobe XD-a preko Creative Cloud-a?!
Mikkin
Poštovan
Pokusao sam da instaliram adobe Xd , ali nikako to ne mogu da ucinim, pratio sam neke tutorijale kako da fixam to, ali nikako nece pa nece.
Imate li vi neku ideju?
Prvo sam dobivao ovaj error:
Kod:
Exit Code: 183 -------------------------------------- Summary -------------------------------------- - 2 fatal error(s), 0 error(s), 1 warnings(s) FATAL: Error (Code = 183) executing in command 'RunProgramCommand' for package: 'UWPAssets', version:0.8.22.17 FATAL: Error occurred in install of package (Name: UWPAssets Version: 0.8.22.17). Error code: '183' WARN: Program "C:\Program Files\Common Files\Adobe/Adobe Experience Design CC (Beta)/CSDKConfigurator.exe" failed with exit code: -1 -------------------------------------------------------------------------------------
Sto je interesatno, mogao sam ostale programe da instaliram , ali adobe xd nisam mogao.
Onda sam pratio sledece intrukcije : https://forums.adobe.com/thread/2344716 i jos neke bonus, i sad dobijam ovo :
Kod:
Exit Code: 191 -------------------------------------- Summary -------------------------------------- - 2 fatal error(s), 2 error(s), 0 warnings(s) FATAL: Error (Code = 191) executing in command 'AddUWPAppxCommand' for package: 'UWPAssets', version:0.8.22.17 FATAL: Error occurred in install of package (Name: UWPAssets Version: 0.8.22.17). Error code: '191' ERROR: hdhelper exe at C:\Program Files (x86)\Adobe\Adobe Creative Cloud\HDCore\HDHelper.exe failed to install UWP app with xml Adobe.CC.XD C:\adobeTemp\ETRECB5.tmp\2\SparklerApp\SparklerApp.appx 0.8.22.17 x64 CN=Adobe Systems Incorporated, OU=Adobe Systems, O=Adobe Systems Incorporated, L=San Jose, S=California, C=US, SERIALNUMBER=2748129, OID.2.5.4.15=Private Organization, OID.1.3.6.1.4.1.311.60.2.1.2=Delaware, OID.1.3.6.1.4.1.311.60.2.1.3=US adbxd: Microsoft.VCLibs.140.00 14.0.24123.0 x64 CN=Microsoft Corporation, O=Microsoft Corporation, L=Redmond, S=Washington, C=US C:\adobeTemp\ETRECB5.tmp\2\SparklerApp\Dependencies\x64\Microsoft.VCLibs.x64.14.00.appx false with error code 1 ERROR: Failed to install UWP Appx Package -------------------------------------------------------------------------------------
Pomoc?
Kontaktiraj Adobe podrsku.
