Melhisedek
Kao prvo da se izvinem za poruku na engleskom, ali sam je slao na 2 engleska boarda pa me sad toliko mrzi da sve ponovo pisem
Nadam se da nece biti neprijatnih represalija niti FX
Hi guys !
Well I thought it's best to ask here before I made any wierd desisions
I have P4 2.26 @ 2.42
512 MB RAM ( 2100 & 3200 ) @ 142 MHz Buss
Sparkle GF4 4200 ( non o/c )
Abit BD7 II Raid mo/bo
DX 9.0
WIn XP Home SP1
Det 42.01
AGP 4x
Well there are two things:
1. I get almost the same marks in 3D2k1 Mark ( round 11 000 ) running it stock ( no tweaks in Control Panel just AA and AS off ) and running it with Vsync off, Bittblock thingy, Best setting in D3D!
Running with stock I got like 10990 and with "tweaks" 11085
2. This one is when o/c my GF 4
It's default cloks are 250/446 I cant clock memory higher than 560 no matter what... I tried coolbits and Riva Tuner... Always the same results. Well I mean I can o/c it higher but I get some pretty bad artifacts
I've seen peeps clockin their cards up to 350/600 at least so I wonder if these are with artifacts ( just for benching ) or totally stable?
I tried everything... Better cooling, flashed to newest BIOS ( 37-one [ just marginal increase in marks if anyone is intressted ] ), different drivers ( from 3x.xx to 42.01 ), but nothing helps.
I have my PCI/AGP buss locked at 33/66 ( maybe that is the problem )
Well I can't say I'm happy with performance either...
I tried running Silent Hill 2 at 1280xsomething without any goodies and it is stuttering quite a bit
It won't go over 30 fps
WarCraft 3 it is much better but it wont go over 37 fps
same res 2x AA and 4x Aniso.
So I don't know... What do U think is this normal or am I smoked with this one. I can't RMA it cause it is working just fine in Win just.My system is very stable no crashes no nothing.
I tried many things but nothing helped.
I heard about one setting in RivaTuner which might help
http://www.guru3d.com/forum/showthread.php?s=&threadid=43128
But I'm not sure if it will work if I don't have ALI chip ( don't even know what it is )
Well i'm open to suggestions...
Any help would be appreciated!
Thanks in advance !!!
Hi guys !
DX 9.0
WIn XP Home SP1
Det 42.01
AGP 4x
