imam plocu SE7520BD2SATAD2 i moram da izvrsim flashovanje BIOS-a da bi ploca prepoznala Xeon 3.2GHz procesor odnosno microcode. evo sta pise u uputstvu za flashovanje
"Bootable storage Update(size > 5MB):
Note: BOOT BLOCK changed, please run fbb.bat to update BIOS.
1. Extract BIOS.ZIP to a bootable storage such as USB DISK-ON-KEY.
2. Boot the system and press <F2> to run BIOS Setup.
3. For reference Write down the current custom changes to any default settings
in the BIOS Setup program. CMOS settings will be preserved across BIOS
updates, but you may wish to use the "Save Custom Defaults" option on the
Exit tab to restore defaults later. Press <ESC> to exit BIOS Setup.
4. Place the bootable storage such as USB DISK-ON-KEY containing the new BIOS
into USB port of the system, and boot to pure DOS mode. (non-himem environment)
5. Run fbb.bat to update both system ROM and bootblock.
**NOTE** : jumper J1B1 (BIOS partition selection) should be set to
pins 1-2 to select the correct BIOS partition.
6. Please use the latest distributed tools (fbb.bat/afudos.exe)
to update BIOS.
Command "fbb.bat" will program main BIOS & bootblock.
7. When BIOS flash update is complete, it will display a message that all
writing and verification of flash is done.
Next, power cycle the system.
8. If the FLASH process fails, please follow the BIOS Recovery Instructions
at the end of this document to recover the system BIOS.
9. Press <F2> to enter BIOS Setup, and verify the custom values you wrote
down in step 3 have been preserved. If you used the "Save Custom Defaults"
option, you can now "Load Custom Defaults".
Press <F10> to save the values and exit Setup."
Dakle treba mi butabilna USB disk. Ja ga nemam ali imam eksterni hard WD od 160GB u fijoci koja se kaci na USB. Da li se ona moze iskoristiti za ovo?
Ako moze kako napraviti da ovaj hard bude butabilan i da ga prilagodim ovom uputstvu?
Moze li mi ko pomoci?
to update BIOS.
