Mayin
Hteo bih da uzmem neki jeftiniji resiver preko oglasa,pa posto nista ne znam o temi treba mi vasa pomoc.Znam samo da mora da bude digitalni i da ima slobodne kanale.Sada cu navesti nazive modela a vi mi pomozite sto vise mozete.Predlozite bar 2-3 u slucaju da je neki prodat dok ja ovu dilemu resim.Hvala unapred!
1.Showbox easy S 300 PVR (2.500 din)
Specificaties:
SHOWBOX S 300 PVR
Specification S-300
166MHz ARM 946 processor ( CX-24303)
5000 Channels programmable (TV 4000, Radio 1200)
Animated Graphic User Interface
1 Cardreader ( multycrypt)
Blind Scan
Fast Scan
Multi Channel Display
USB 2.0 Host Support (MP3, JPEG, Text viewer, S/W update)
PVR Ready (Recording and playback, Trick mode,
Timeshift via external HDD or Memorystick)
Multipicture , Zoom , Save screen picture ,
2.Panasonic TU-DSB40 2002 godiste(to mi je sumnjivo i matoro)1.500din
mora da je analogni?
1x, NDS Videoguard Cardreader (BSkyB), Modem, OpenTV
Receiver Type: Standard Definition
3.Echostar DSB-808 2 2003 godiste 2.000din
n 2 Common Interface Slots
n 4,000 Channels, 100 Satellites, 1,300 Transponders
n 7 Day EPG
n 8 Favorite Lists for TV and 8 for Radio
n Digital Audio Output (Dolby Digital Compatible)
n DiSEqC™ 1.2
n EchoNav Multilingual Advanced User Interface (12+ languages)
n Embedded Conax
n Multiple Scan Modes (incl. Update Scan)
n Powerful Channel Sorting and Grouping
n Software Updates via Internet/Satellite (OTA)
4.Amiko SSD-540 FTA 2010 god
Digital Satellite Receiver
Free-To Air
Automatic Install function
4 (7 segment) digit LED display
Powerful Channel Management tools (Lock, Edit, Move, Skip, Delete)
Favourites
User Friendly On-Screen Display (OSD)
Multi-Language support
Subtitles support (DVB/TXT)
DiSEqC 1.0, 1.2 and USALS compatible
5.Strong SRT 6011 2.800din
Excellent Audio & Video quality
Display showing channel number or time
Signal strength bar for digital transponders
Mosaic function: 9 TV Channel in overview
Features
For all digital Free-To-Air TV and Radio programmes via satellite
3 seconds Replay
Digital sound through coaxial output (S/PDIF)
Separate power switch
Set-up support for first time installation
Max. 4.800 channel memory capacity for 64 satellites
Astra and Hotbird channels pre-programmed
4 Favourite lists for TV-and Radio programme
Quick and easy installation & user-friendly menu
Parental lock function for menu and selectable per channel
Teletext via OSD & VBI
Supports DiSEqC 1.0, DiSEqC 1.2 and GOTO X
Electronic Programme Guide (EPG) for present/following event information and up to 7 days for on screen programme information
Full multi-lingual DVB subtitling and audio track support
Multi-lingual support on screen menu (OSD): English, German, French, Italian, Spanish, Russian, Croatian, Romanian, Czech, Hungarian, Polish
Edit functions for TV or Radio programme name and satellite name
Future-proof: Software update via satellite (OTA)
Automatic, network and manual channel scan options
Power on with last viewed channel
10 Timer for recording and/ or sleep-timer with 3 modes (daily, weekly, once)
5 Games (Boxman, Mine, Tetris, Rush, Gomoku)
User-friendly remote control with coloured function buttons
Low power consumption
Connections: SAT IN, SAT OUT, 1 Scart TV (RGB/CVBS), 1 Scart VCR (CVBS), 3 RCA (Video, Audio Left & Right ), S/PDIF, Serial Port RS 232, power switch
Connectors:
SAT IN
SAT OUT
2 SCARTS TV (RGB, CVBS) / VCR (CVBS)
3 RCA (Video, Audio Left & Right),
S/PDIF: coaxial output
Data Interface – serial port: RS 232, 9-Pin D-Sub Male type
Audio Decoder:
ISO/IEC 11172 LAYER I&II
Sampling rate: 32, 44.1, 48 kHz
Audio modes: Stereo, Joint stereo, Dual mono, Mono
Video Decoder:
Profile level: MPEG2 MP@ML
Input Rate: Max. 60 Mbits/s
Video Resolution: 720 x 576 (PAL), 720x 480 (NTSC) pixels
Aspect Ratio: 4:3, 16:9
Demodulator:
Modulation: QPSK
Input Symbol Rate: 2~45 Ms/s
SCPC /& MCPC signals from C & KU and satellites
System and Memory:
Flash Memory: 16 Mbits
SDRAM: 64 Mbits
Tuner:
Front-End: DVB-S
Input Frequency Range: 950~2150 MHz
RF Input Level:-25~-65 dBm
LNB Power: 13/18 V DC (+/- 5%)
Max. 500 mA, Overload protected
DiSEqC Version: 1.0 & 1.2
6.opentel ods3000c 1550din
Receiver Type: FTA
Manufacturer - Hersteller: He@d
Production - Produktion: 2005
- MPEG-2 Digital & Fully DVB Compliant
- 4000 Speicherpl?tze f?r TV- und Radioprogramme
- bis zu 1000 Favoriten
- Dolby-Digital Ausgang (AC3)
- Automatische Formatsanpassung (16:9, 4:3)
- Multisprachen OSD
- Teletext
- EPG
- 4-stellige Kanalanzeige
- 2 x Scart (RGB und FBAS)
- DiSEqC 1.2 und USALS
8.Free to Air USB 771 Satellite receiver 3.000din
Hardware blind search supported (No need frequency and symbol rate).
RGB output supported.
USB2.0 interface
Support MP3, JPG image and photo display
External USB hard disk, U disk or PC recoding programs supported, ts stream recoding supported.
Fully DVB-S / MPEG ˝C2 compliant.
5000 channels memory space
SCPC & MCPC receivable from C/Ku band satellites
256-color on screen display (OSD).
Video Outputs Support for all NTSC, PAL B/G, I, D/K, N, M, SECAM worldwide standards, and Macrovision copy protection supported
DiSEqC 1.0/1.1/1.2/1.3(USALS) supported
Multi-language OSD (Hungary, English, German, Italian, Spanish, French, Turkish, Arabic, Persian, Greek, Portuguese, Russian, Polish etc.).
Multi-language audio and subtitle reception
Electronic program guide (EPG) supported
Teletext and close caption output through VBI and OSD
RF modulator for TV standard (PAL B/G/D/I/K/N/M, NTSC, SECAM)
Two Scart sockets
Digital encoded bit-stream output via S/PDIFˇ¤ Dolby port
Picture in graphics (PIG) supported
NIT search supported
Automatic search & blind-search (HW) for satellites and transponders
Upgrade software from PC to receiver, or from receiver to receiver through RS-232 port
Timer function supported
4:3, 16:9 aspect ratio support through pan/scan or letter-boxing
Games included
Picture in picture (4, 6, 9, 16 PIP available) function
Easy-Installation Menu
Arabic teletext supported
TUNER
Input Frequency: 950~2150MHz
Loop Out Frequency: 950~2150 MHz
Input Level: -65~-25 dBm
Input Impedance: 75
LNB Power: Auto/14V/18V/OFF, Imax = 500mA
CHANNEL DECODING
Waveform: QPSK
Roll Off Factor: 0.35
FEC: 1/2, 2/3, 3/4, 5/6, 7/8, Automatic
Reed Solomon: 204, 188, t = 8
Symbol Rate: 1.0~45 MS/s
DEMULTIPLEXER
Standard: ISO/IEC 13818-1
Input Max. Bit Stream Rate: 60Mbps(Serial)/7.5MBps(Parallel)
VIDEO DECODING
Standard: ISO/IEC 13818-2, MPEG-2 MP@ML
Video Resolution: Max. 720x480 @30fps NTSC & 720x576 @25fps PAL
AUDIO DECODING
Standard: ISO/IEC 13818-3
Audio Channel: Mono, Dual-channel, Stereo, and Joint Stereo
Sampling rates: 16, 22.05, 24, 32, 44.1, 48kHz
PROCESSOR AND MEMORY
CPU: CX24303
Clock Frequency: 150MHz
Flash Memory: 2M bytes
SDRAM Memory: 8M bytes
AV OUTPUT
Video De-emphasis: CCIR REC.405-1, 625LINES
Video Bandwidth: 5.5MHz
Video Output Impedance: 75
Video Output Level: 1.0Vp-p
Audio Output: Mono, Left/Right Stereo
Audio Output Frequency: 20Hz~ 20KHz
Audio Output Impedance: Low
Audio Output Level: 0 6dBu
FRONT PANEL
LED Display: 4-digit LED to indicate channel number and status
Keys: Up, Down, Left, Right, Menu, OK
IR Receiver: 38KHz
REAR PANEL
RF Input: F-type,connector
Loop Through Output: F-type,connector
RCA Output: 4RCA(1 Left Audio,1 Right Audio,1 Video, 0/12V)
RS232 Serial Port: DB-9 Male, 11.52Kbps
SCART: 2(VCR,TV) (optional)
Digital Audio Output: S/P DIF Fiber-optical
9.phonotrend sdr 600 izasao pre oko 6 god 1550din
Specificaties:
SHOWBOX S 300 PVR
Specification S-300
Blind Scan
Fast Scan
n 7 Day EPG
n DiSEqC™ 1.2
n Embedded Conax
Free-To Air
Favourites
Features
3 seconds Replay
Connectors:
SAT IN
SAT OUT
Audio Decoder:
Video Decoder:
Demodulator:
Modulation: QPSK
System and Memory:
SDRAM: 64 Mbits
Tuner:
Front-End: DVB-S
Receiver Type: FTA
- Multisprachen OSD
- Teletext
- EPG
USB2.0 interface
Two Scart sockets
Games included
TUNER
Input Impedance: 75
CHANNEL DECODING
Waveform: QPSK
DEMULTIPLEXER
VIDEO DECODING
AUDIO DECODING
CPU: CX24303
AV OUTPUT
FRONT PANEL
IR Receiver: 38KHz
REAR PANEL
