Potrebna pomoc oko ploce i procesora
lazicdanijel
Posto sam nasao kupca za staru plocu i procesor interesujeme sta preporucujete od ovoga!!!
Asus M3N78 SE,nForce 720D (MCP78D),HT3 5200,DDR2 1066,1 x PCIe,SATA 3Gb/s*4(RAID 0, 1, 0+1, 5, JBOD),GLAN
Asus M3N78,AM2+(up to 140W),GeForce 8200,DDR2 800,VGA GeForce 8 Series,HDMI/DVI/RGB,RAID Support,GLAN
Asus M3N78-EM,GeForce 8300 (MCP78U),HT3 5200,DDR2 1066,VGA 256M,Hybrid SLI,ESATA,2x1394a,GLan,uATX
MSI SAM2 K9AGM3-F 690V+SB600/1000HT/4XDDRII 800MHz/PCI-E/VGA onboard/SATAII/7.1ch/GLAN
MSI SAM2 K9AGM4-L/690V+SB600/1000HT/4GB DDRII 800MHz/PCI-E/vga onboard 256MB/SATAII/5.1ch/LAN
MSI SAM2 K9N NEO-F nF 520/1000HT/4xDDR800MHz/PCI-E/SATA II/RAID/7.1ch/GLAN
MSI SAM2 K9A2GM-F V3/740+HD2100+SB700/2600HT/DDRII 800MHz/PCI-E/vga onboard 256MB/7.1ch/GLAN
MSI SAM2 K9A2VM-F/780V+SB700/2600HT/max4GB DDRII 1066MHz/PCI-E/256MB VGA onboard DX10/SATAII/8.0ch/GLAN
MSI SAM2 K9N NEO-F nF 560/1000HT/max8GB;4xDDRII800MHz/PCI-E/SATAII/RAID/7.1ch/GLAN/Heatpipe
MSI SAM2 K9N2GM-FIH/GeForce 8200/2600HT/4xDDRII 1066MHz/PCI-E/256MB VGA DX10/HDMI/SATAII/8.0ch/GLAN
MSI SAM2 KA780G/780G+SB700/5200HT/max8GB DDRII 1066MHz/VGA onboard 256MB/HDMI/DVI/SATAII/7.1ch
i procesori
AMD AM2 Athlon™ 64 X2 Dual-Core 5000+ Brisbane 64 Bit 2.6GHz 2x512KB HT2000MHz 65nm 65W BOX
AMD AM2 Athlon™ 64 X2 Dual-Core 5200+ Brisbane 64 Bit 2.7GHz 2x512KB HT2000MHz 65nm 65W BOX
AMD D.Core A64 X2 AM2 5400+
AMD AMD Phenom™ X3 Triple-Core 8650 ( 2.3GHz,1.5MB,95W,AM2+ ) Box
HVALA!!!!!
Asus M3N78-EM + Athlon™ 64 X2 5000+
Ovu ploču sam ja uzeo za HTPC. Ne znam za šta će sve tebi služiti računar, ali ja bih uzeo gore navedeni CPU pa ga naknadno apgrejdovao nekim 45nm. Ne bih sada bacao pare ni na šta skuplje od 5000+, jer su sve to procesori starije generacije...
