Evo kako
3.2 Dwemer Puzzle Box
After getting equipped, return to Caius and ask about your "orders".
Caius will mention that he needs information from a man named Hasphat
Antabolis in the Balmora Fighters Guild. Caius will also mention that
you will most likely need to do a favor for Hasphat before he will tell
you anything. Before you go, Caius will give you access to any books in
his house.
To get to the Fighters Guild, cross the northernmost bridge to the west
side of town, go up the first flight of stairs and turn south before
you get to the second flight. The Fighters Guild is on the left, and
Hasphat is downstairs in the lower level. Once you speak with Hasphat
you will find out that he will be happy to give up the information....
For a price. He requests you to retrieve a Dwemer Puzzle Box from a
ruin named Arkngthand.
To get to Arkngthand, head south out of town past the Silt Strider
port, then cross the bridges east over the Odai River. At the sign
post, head north towards Caldera. Immediately on the right you will see
a signpost for Molag Mar, turn right and head uphill on an old road to
cross an ancient Dwemer Bridge over Foyada Mamaca (note that a wizard
will attack you the first time you cross this bridge, he will summon a
skeleton, defeat the wizard and both will disappear). The entrance is
on the east side of the foyada, south of the bridge. Turn a crank on a
pipe nearby to open the door.
To find the cube, follow the rocks on the side of the wall all the way
to the bottom floor of the room. There will be rocks in front of you,
climb them until you are on the second floor on the west side of the
cavern. Go through the door into the "Cells of Hollow Hand" (If you
follow the above directions you should end up in the Cells of Hollow
Hand near the begining of the dungeon, not deep within the dungeon).
Defeat the guy inside, his name is Boss Citra (if he is not in the
room, then you are in the wrong room.), the Puzzle Box is on the
bottom shelf to the left of the door (as you enter, right if you are
facing the door. I assure you that the box is in this room on one of
the shelves, It is the size of a rubics cube. If you can't find it,
check every shelf). Grab the box and backtrack out of the dungeon.
Return the box to Hasphat in Balmora.
