Pomoc oko IKOM kablovske
turbostribor
Pozdrav.Molio bih ljude koji imaju IKOM kablovki net da mi pinguju ovu adresu : 88.198.35.46 i postave rezultat ovde,a pritom navedu njihov paket i otprilike lokaciju gde se nalaze.Takodje bih vas zamolio da mi kazete kakva su vasa iskustva sa ovim operaterom tj. da li cesto puca veza ili trokira i kakvi su vam pingovi u igrama.Ovo mi je dosta vazno jel imam ptt kablovsku i smorila me vise njihova pateticna brzina.Probao sam i telekomov adsl,ali me ubi ping.Tako da mi jos ovo preostaje,jer za sbb nema tehnickih mogucnosti.Hvala unapred.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\D>ping -t 88.198.35.46
Pinging 88.198.35.46 with 32 bytes of data:
Reply from 88.198.35.46: bytes=32 time=47ms TTL=48
Reply from 88.198.35.46: bytes=32 time=52ms TTL=48
Reply from 88.198.35.46: bytes=32 time=59ms TTL=48
Reply from 88.198.35.46: bytes=32 time=73ms TTL=48
Reply from 88.198.35.46: bytes=32 time=43ms TTL=48
Reply from 88.198.35.46: bytes=32 time=89ms TTL=48
Reply from 88.198.35.46: bytes=32 time=45ms TTL=48
Reply from 88.198.35.46: bytes=32 time=44ms TTL=48
Reply from 88.198.35.46: bytes=32 time=65ms TTL=48
Reply from 88.198.35.46: bytes=32 time=54ms TTL=48
Reply from 88.198.35.46: bytes=32 time=61ms TTL=48
Reply from 88.198.35.46: bytes=32 time=88ms TTL=48
Reply from 88.198.35.46: bytes=32 time=46ms TTL=48
Reply from 88.198.35.46: bytes=32 time=91ms TTL=48
Reply from 88.198.35.46: bytes=32 time=67ms TTL=48
Reply from 88.198.35.46: bytes=32 time=62ms TTL=48
Reply from 88.198.35.46: bytes=32 time=50ms TTL=48
Reply from 88.198.35.46: bytes=32 time=76ms TTL=48
Reply from 88.198.35.46: bytes=32 time=81ms TTL=48
Reply from 88.198.35.46: bytes=32 time=53ms TTL=48
Reply from 88.198.35.46: bytes=32 time=64ms TTL=48
Reply from 88.198.35.46: bytes=32 time=110ms TTL=48
Reply from 88.198.35.46: bytes=32 time=79ms TTL=48
Reply from 88.198.35.46: bytes=32 time=42ms TTL=48
Reply from 88.198.35.46: bytes=32 time=57ms TTL=48
Reply from 88.198.35.46: bytes=32 time=69ms TTL=48
Reply from 88.198.35.46: bytes=32 time=51ms TTL=48
Reply from 88.198.35.46: bytes=32 time=40ms TTL=48
Ping statistics for 88.198.35.46:
Packets: Sent = 45, Received = 45, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 40ms, Maximum = 110ms, Average = 60ms
Paket 512/256. Zarkovo. Radilo super do pocetka juna (od oktobra), onda par dana zezalo, sad izgleda da opet radi bez problema. Za igrice ne znam koliko ti je ovo dobar ping, ali za one koje ja igram (MMORPG) je i vise nego dovoljan.
Hvala puno na brzom odgovoru.Pretpostavljam da nisi nista downlodaovao dok je trajalo pingovanje?Onda bi ipak bilo bolje da zadrzim ptt jer imaju malo bolji ping cini mi se.Hvala jos jednom:)
Nisam nista downloadovo. Koliko vidim to je neki nemacki server, tako da ne verujem da bilo koji nas provider moze imati bolji ping od 50 (prosecno) do njega. Znaci ako ti ptt radi izmedju 50 i 60 to je otprilike to cemu mozes da se nadas u Srbiji :)
Pa da u pravu si za ping,verovatno ne moze nesto bolje.Ok.Puno ti hvala,mnogo si mi pomogao.Ipak cu se zadrzati na adslu jer ima slican ping kao IKOM,a ako mi dune vremenom mogu i da promennim sada kada znam otprilike koliki su pingovi.:)Hvala ti jos jednom sto si se iscimao.
Zaboravio sam da pitam i ako bi neko mogao da pinguje google,molim vas.Hvala.
Pinging www.1.google.com [209.85.129.401] with 32 bytes of data:
Reply from 209.85.129.104: bytes=32 time=60ms TTL=224
Reply from 209.85.129.104: bytes=32 time=36ms TTL=224
Reply from 209.85.129.104: bytes=32 time=50ms TTL=224
Reply from 209.85.129.104: bytes=32 time=51ms TTL=224
Reply from 209.85.129.104: bytes=32 time=22ms TTL=224
Ping Statistics for 209.85.129.104:
Packets: Sent = 11, Received = 11, Lost = 0 <0% loss>,
Approximate round trip in milli-seconds:
Minimum = 22ms, Maximum = 60ms, Average= 43ms
Jesi ovo pingovao sa IKOM-a ? Posto vidim da si iz Krusevca, a pishe ti da imas adsl net. Cisto da ne bude zabune jer njega interesuje ping sa IKOM-a :)
Evo sa IKOM-a:
Pinging www.l.google.com [209.85.135.147] with 32 bytes of data:
Reply from 209.85.135.147: bytes=32 time=42ms TTL=242
Reply from 209.85.135.147: bytes=32 time=40ms TTL=242
Reply from 209.85.135.147: bytes=32 time=43ms TTL=242
Reply from 209.85.135.147: bytes=32 time=72ms TTL=242
Reply from 209.85.135.147: bytes=32 time=56ms TTL=242
Reply from 209.85.135.147: bytes=32 time=94ms TTL=242
Reply from 209.85.135.147: bytes=32 time=41ms TTL=242
Reply from 209.85.135.147: bytes=32 time=60ms TTL=242
Reply from 209.85.135.147: bytes=32 time=54ms TTL=242
Reply from 209.85.135.147: bytes=32 time=48ms TTL=242
Ping statistics for 209.85.135.147:
Packets: Sent = 14, Received = 14, Lost = 0 (0% loss),
Minimum = 40ms, Maximum = 94ms, Average = 51ms
Trenutno sam u Bg-u (spremam prijemni). Pa sam kod tetke koja ima ikom cable...
Offtopic 2^11 post (2048.)
