Pomoc oko cuvenog plavog ekrana
pilauda
CPU & Cooler
7800x3D & Dark Rock 4
Matična ploča
GigaByte B650M Aorus Elite AX
RAM
2 x 16GB DDR5 Kingston 6000 CL30
GPU
MSI RTX 4080 SUPER 16G GAMING X SLIM
Storage
Samsung 990 pro 2TB , Silicon Power 2TB
Zvuk
2.1 Logitech Z313
PSU
FSP Hydro G PRO 1000W ATX3.0
Kućište
CoolerMaster MasterBox TD500 MESH
Monitor
Gigabyte 27'' AORUS FO27Q2 OLED
Miš & tastatura
Dareu A950 Wing, Razer Cynosa V2
Ostale periferije
Xbox Series X
Laptop
HP 15s-eq2083nm
Mobilni telefon
iPhone 13 mini
Pristup internetu
  1. Optički internet
Pocelo je da se desava vrlo ucestalo, tipa kad upalim komp i posle par minuta upali se plavi ekran i krene da vrti procente oko dump memorije kolko sam mogao da primetim, odradio sam debug preko symbola mini dump fajlu i evo sta kaze:
Microsoft (R) Windows Debugger Version 6.9.0003.113 X86
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\051610-17908-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: C:\Windows\Symbols
Executable search path is:
Unable to load image \SystemRoot\system32\ntoskrnl.exe, Win32 error 0n2
*** WARNING: Unable to verify timestamp for ntoskrnl.exe
Windows 7 Kernel Version 7600 MP (2 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7600.16539.amd64fre.win7_gdr.100226-1909
Kernel base = 0xfffff800`02e01000 PsLoadedModuleList = 0xfffff800`0303ee50
Debug session time: Sun May 16 10:38:40.048 2010 (GMT+2)
System Uptime: 0 days 0:04:01.108
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
Ima li ovde nekakve pomoci, kako da sprecim da se ovo vise ne desava? Hvala unapred!
Ukoliko imaš više memorijskih modula, vadi jedan po jedan, ispitaj više kombinacija, pa vidi šta se dešava.
Kao prvo skini program BlueScreenView, on ce ti omoguciti da jasno procitas sta sve pise na tom plavom ekranu ili BSoD.
Pokusaj sledece:
-Uradi update svih komponenata (MB, HDD, Graficke kartice, Mrezne, Zvucne itd)
-Uradi update bios-a
-Testiraj memoriju sa programom memtest86
-Promeni nacin napajanja u Windows-u
Ako to ne resava nista onda probaj onda da uradis to sto ti je napisao theemp
pa ako si u mogucnosti da probas sa drugim Ram modulima, HD, napajanjem itd. Isprobaj Hardver.
Idi na Computer>desni klik>Manage>Event Viewer imaces vise informacija o gresci.
Jel ti se desava isto u Safe Mod-u?
Javi dali je problem resen
www.geeksinfo.net
Kod mene se slicno desavalo dok na kraju nije zakucao- izvadio jedan od dva mem. modula i sada radi bez bsd-a vec par dana... Djavolja naprava.
Pusti memtest ili neki slican program pa vidi sta kaze.
Ako već budeš puštao neki program za testiranje memorije pusti Gold Memory.
premestio sam sa ova dva slota na druga dva slota, prosao je jedan dan bez bsd-a, videcemo jos par dana sta ce da bude
Druze, vec sam napisao negde na ovom forumu da sam i ja imao takav problem i da sam ga resio sa RegCure programom. Znaci skini ga negde ali obavezno sa krekom i resices problem!
Pozdrav
Ako ti ne daj bože opet izbaci bsod, probaj sa samo jednim modulom. A u međuvremenu provrti gold memory.
Obori klok memorije ili opusti latencije.
da ne otvaram novu temu, meni se u poslednjih 5 dana dva puta pojavio plavi ekran i to oba puta u toku video chata preko MSN messengera... drugi put je bilo pre 10 min, evo sta je pisalo...
Cini mi se da je se javilo dosta korisnika sa istim problemom, probaj da apdejtujes drajvere za kameru ili da mozda koristis nizu ili visu verziju messengera.
www.geeksinfo.net
This error is usually caused by a hardware failure, more often than not, faulty RAM. If you have SCSI equipment installed, disable sync negotiation in the SCSI BIOS and check SCSI termination.
This error may also be caused by over-clocking.
Po ovome i onome piše na samom bsod, proveri memoriju i ako si nešto oc, vrati na defoltne vrednosti.
Ovako meni se to nekada desava, zbog wlana, imam tp-link g422, pa se zbog njega desavao problem na windowsu7 i ponekad na xp u.
