Pojacati signal?
cvele1_kv
Poz svima,totalni sam laik sto se tice w-lan-a,pa mi treba konkretan odgovor,naime dok sam imao laptop koristio(krao sam) net od nekog iz komsiluka(mislim da je kafic iz komsiluka) e sad sam presao na stoji racunar i u njemu imam tp-link tl-wn350gd,
da li mogu na ovuy karticu da nakacim neku antenu i da pojacam signal i kvalitet interneta ili da uiradim nesto drugo u cilju boljeg prijema,jer ovako po nekad varira signal i cesto je veoma slab.ovo je spec. od kartice
Standards
IEEE 802.11g, IEEE 802.11b
Wireless Signal Rates With Automatic Fallback
11g: Up to 54Mbps (Dynamic)
11b: Up to 11Mbps (Dynamic)
Frequency Range
2.4 GHz
Output Power
18dBm
Modulation Type
1M DBPSK, 2M DQPSK, 5.5M/11M CCK, 6M/9M/12M/18M/24M/36M/48M/54M OFDM
Receiver Sensitivity
54M:-68dBm@10% PER
11M:-85dBm@8% PER
6M:-88dBm@10% PER
1M:-90dBm@8% PER
256K:-105dBm@8% PER
Work Mode
Ad-Hoc
Infrastructure
Wireless Security
64/128/152 bit WEP
WPA/WPA2, WPA-PSK/WPA2-PSK (TKIP/AES)
Support Operating System
Windows 2000/XP/Vista
*:EIRP-total effective radiated power is 100dBm(100mW), antenna gain will not influence wireless transmit power
Hardware Specification
Interface
32-bit PCI connector
Antenna
2dBi Detachable Omni-directional Antenna
(Reverse SMA Connector)
Certifications
CE, FCC
Operating Temperature
0°C~40°C (32℉~104℉)
Storage Temperature
-40°C~70°C (-40℉~158℉)
Relative Humidity
10% ~ 90% non-condensing
hvala
Storage Humidity
5%~95% non-condensing
Dimensions
5.2 × 4.8 × 0.9 in. (133 × 121 × 22 mm)
Lepo se ja i ti dogovorimo preko poruka gde da s enadjemo da ti prodam antenu i sve reseno :))
16DB grid antena, sa vec postavljenim konektorom za tu kartu ;)
