PHP Nuke Forum Administration sa BLANK stranom, help
IvanziLLa
Pozdrav narode, imam jedan rekao bih standardan problem sa upgrade-om foruma u PHP Nuke.
Imam 7.5 verziju Nuke-a, sa 3.11 patch fajlom....
Ali, da se vratimo forumu... Problem je nastao pri upgrade-u istog od 2.0.12 --> 2.0.17 ! Sada kada je završen upgrade ne mogu više da uđem u Forum/Administration 🙁 Iako sam pre to mogao!!!
Pojavljuje mi se prazna strana ili ti BLANK PAGE!!!
Probao sam sa ponovnim uploadom fajlova iz Modules/Forums foldera, ali ništa! I da, najzad sam uključio prikazivanje greški, i dobio sledeći rezultat 🙂
Warning: main(includes/constants.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 200
Warning: main(): Failed opening 'includes/constants.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 200
Warning: main(includes/template.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 201
Warning: main(): Failed opening 'includes/template.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 201
Warning: main(includes/sessions.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 202
Warning: main(): Failed opening 'includes/sessions.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 202
Warning: main(includes/auth.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 203
Warning: main(): Failed opening 'includes/auth.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 203
Warning: main(includes/functions.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 204
Warning: main(): Failed opening 'includes/functions.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 204
Warning: main(db/db.php): failed to open stream: No such file or directory in /home/mega/public_html/modules/Forums/common.php on line 205
Warning: main(): Failed opening 'db/db.php' for inclusion (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mega/public_html/modules/Forums/common.php on line 205
Fatal error: Call to undefined function: encode_ip() in /home/mega/public_html/modules/Forums/common.php on line 217
Nadam se da je prisutan neko ko zna kako mogu da ispravimi problem, i nateram (bas nateram) Forum Administration to work
