PHILIPS DVP-5960 HDMI utisci
djwibe
PHILIPS DVP-5960
Picture / Display
Aspect ratio : 4:3, 16:9
D/A converter : 12 bit, 108 MHz
Picture enhancement : High Def (720p, 1080i), Progressive scan, Smart Picture, Video Upsampling, Video upscaling
Sound
D/A converter : 24 bit, 192 kHz
Signal to noise ratio : 100
Distortion and noise (1kHz) : 85 dB
Crosstalk (1kHz) : 100 dB
Dynamic range (1kHz) : 90 dB
Sound system : Dolby Digital
Frequency response : 30-20000 Hz
Video playback
Playback Media : CD, CD-R/CD-RW, Video CD/SVCD, DVD, DivX, DVD+R/+RW, DVD-R/-RW
Compression formats : MPEG1, MPEG2, DivX 3.11, DivX 4.x, DivX 5.x, DivX 6.0, DivX Ultra
Video disc playback system : PAL, NTSC
Audio Playback
Playback Media : CD, MP3-CD, MP3-DVD, CD-R/RW, WMA-CD
Compression format : Dolby Digital, MP3, PCM, WMA
MP3 bit rates : 32 - 256 kbps
Still picture playback
Playback Media : DVD+R/+RW, DVD-R/-RW, CD-R/RW, Picture CD, Kodak Picture CD
Picture compression format : JPEG
Picture enhancement : Flip photos, Rotate, Zoom, Slideshow with MP3 playback, High Definition Resolution
Multimedia Applications
Multimedia connections : USB memory class device
Playback formats : DivX, MP3, JPEG still pictures
Connectivity
Rear Connections : Analogue audio left / right out, Composite video (CVBS) output, HDMI output, Digital coaxial out, Component video out progressive, Scart
Convenience
Child Protection : Parental control, Child lock
On-screen display languages : English
Accessories
Included accessories : 2 x AAA Batteries, Quick start guide, Remote control, World-Wide Warranty leaflet, User manual
Dimensions
Set Width : 435 mm
Set Height : 37 mm
Set Depth : 235 mm
Packaging Depth : 320 mm
Packaging Height : 82 mm
Packaging Width : 490 mm
Power
Power supply : 50Hz, 240V
Power consumption : < 10 W
Standby power consumption : < 0.8 W
Ima li neko i kako je njime zadovoljan.
Ima li 5.1 izlaz posto po spec. nevidim da ima.
Neka slika zadnjeg dela.
znaci, uredjaj stigao veceras, kupljen u Tehomarketu, danas su dobili jos nekoliko komada, i odmah prodali...
sutra moram da ubacim novi i modifikovani firmware za nasu 1250 kodnu stranu...
ako sve bude po planu, preko mog prijatelja Ivice stize HDD 120Gb i USB fioka...
zurka pocinje...
zurka pocinje...
Ajde isprobaj ga pa ostavi ovde utiske o radu.
resio sam da ga kupim...
nije ga bilo u BG-u, pa sam dogovorio da povuku 1kom iz prodavnice iz Srbije...
linkovi prema nekim forumima i topicima:
http://board.softpedia.com/index.php?showtopic=4372
http://www.divxmania.it/index.php?showtopic=9009
http://www.videohelp.com/dvdplayers.php?DVDnameid=7060&Search=Search&#comments
sajt jednog vlasnika 5960:
http://www.phunkyfish.com/article/4/philips-dvp-596012
utisci za par dana...
poz...
Sta bi sa utiscima
ubacio sam modifikovani firmware...
`proradila` su nasa slova, sad su bela, velika, to je ok...
povezao sam USB rack+HDD 120Gb, vecina filmova je ok, jedino...
pustim Dirty Dancing, ali mi se cini kao da slika povremeno i vrlo kratko zakoci, na tonu ne primetim, nema desinhonizacije slike i tona...vise puta sam neke scene gledao, i ucini mi se svaki put...
pustio sam jos 10-ak filmova sa HDD-a i svi su ok, i nisam primetio nista sporno...
ubacio sam verziju firmware-a bez `Packed Bitstream support`...
ima i varijanta sa tim...
sta je `Packed Bitstream support`, i da li treba ta da se ubaci?
u principu, zadovoljan sam, slika je ok, uglavnom sam do sada probao DivX, samo me kopka to stucanje...
poz...
poz...
Ako je samo na Dancingu onda je do filma nije verovatno do playera.
Kako stoji stvat sa zvukom.
Ajde ako imas neki DVD sa mp3 muzikom probaj da vidis kako cita diska, dal cita tagove, da li moze da se pravi playlista, da li cita na displeju koja pesma ide,repeat, shuffle, da li ositava pesme na listi cele ili ih sece...
postuj foto TV ekrana da vidimo velicinu fonta.
jel si probao HD?
postoji li neki DVD player koji podrzava HD snimke. Znaci HD snimke na DVD-u, recimo HD DIVX ne mogu da se setim koji je to bese codec. Da li to ovaj Philips podrzava.
nazalost, nista od HD, kao i MP4...
na brzinu sam testirao sa divx cd2.0, i rezultati su otprilike kao i na stranici:
ranije sam pisao da sam razmisljao o kupovini Grundig 3560, koji ima i Nero Digital, ali sam odustao..
cekam sledecu godinu i LCD TV, a onda ce biti i bolja ponuda plejera...
mozda budu i multimedijalni uredjaji /sat-prijemnik, DVD, HD plejer i sl/...
kad stignem bacicu sliku sa fontovima, licni utisak - fontovi sa mod. firmware-om OK...
poz...
Ima li jos koga sa ovim Philipsom, da podeli iskustva, kako uredjaj funkcionise.
Nekako, u masi DVD/DivX uredjaja mi se ovaj ukazuje kao najbolje resenje za cifru ispod 100e.
Imam isti taj Philipsov player kojeg sam odmah i prodao dalje,naime isto to "štucanje" sa USB-a bili onaj stick od 1 GB ili više "exsterni" od 250 gb,problem je u USB-u. ZATO ŠTO JE USB 1.0 VERZIJA. A DANAS SE UGLAVNOM KORISTI 2.0..Tako da sam kupio Quadro kojeg sam testirao u trgovini i radi bez greške.Je da je marka briju fiju ali radi bolje nego ovaj Philips... Ubuduće kad se kupuje dvd player bilo linijski ili recorder obvezno obratiti pozornost na USB sučelje da bude 2.0.
Što se ovog DVD player-a tice, sve osim USB funkcije - KESA. HDMI Upscaling - BUDALASTINA, najobicniji marketinski trik (zali boze datih para za kabl). Ovo ne tvrdim iz nekog strucnog ugla, potkrepljen beskonacnim iskustvom, vec onako odokativno. Na 32" LCD-u DVD sa upscaling-om na 720p i 1080i iztgleda i dalje musavo i muljavo. Sto se USB-a tice, ponekad zakoci, ali nije strasno. Meniji su ocajni, a sve ostalo prosecno... Uz upgrade firmware-a tu su i divx titlovi. Podrzava divx 6, ali niko to ne koristi. Sve u svemu - NISTA NAROCITO.
