Palit 8600GT Sonic+ REVIEW part 1
djwibe
Palit 8600GT Sonic+
Specifikacije:
* Core Clock: 625 MHz
* Shader Clock: 1375 MHz
* Memory Clock: 1800 MHz
* Bus interface: PCI Express
* Memory: 256MB
* Memory Interface: 128 bit
* RAMDACs: 400 MHz
* NVIDIA® unified architecture with GigaThread™ technology
* Full Microsoft® DirectX® 10 Shader Model 4.0 support
* 16x full-screen anti-aliasing
* True 128-bit floating point high dynamic-range (HDR) lighting
* NVIDIA® Quantum Effects™ physics processing technology
* Two dual-link DVI outputs support two 2560x1600 resolution displays
* NVIDIA® PureVideo™ HD technology
* HDCP copable
* OpenGL® 2.0 support
* NVIDIA ForceWare® Unified Driver Architecture (UDA)
* NVIDIA® Lumenex™ Engine
* Innovative Cooling System
* Built for Microsoft® Windows Vista™
Utisci:
* Karta je identicne duzine sa npr 7300GT DDR3, ali zbog debljine hladnjaka zauzima 2 slota.
* Cooler/Hladnjak deluju kvalitetno i izgleda da dobro rade posao (po boji hladnjaka reklo bi se da je bakar). U LOAD-u pri dodiru hladnjaka jedva da se oseca toplota.
* Temperature su u IDLE=41-42C, BURN=ispod 60C
* Memorijski chipovi su Quimonda 1ns
* Kod SLI konektora postoji mali beli 2pinski prikljucak za koji neznam chemu sluzi
* U pakovanju su: DVItoVGA adapter, Kablici za VideoOUT, install CD &
* XPEND RALLY EXTREME original igra
OverClock
* Za sada MAX OC bez artifakta je 710MHz/1562MHz/2150MHz (GPU/Shader/Memory)
* Pri 675/1485/2000 daje identicne rezultate kao 8600GTS karte
* Karta prolazi i clockove 765MH/1683MH/2200MH, ali se pojavljuju artifakti. Preko 770 se zakucava.
Slike
Link ka proizvodu
Test
* nVidia ForceWare 163.71 WHQL
* AMD Athlon X2 3600+ Brisbane @ 2.6GHz, def.Voltage
* BIOSTAR NF520-A2 @273FSB, def.Voltage
* KINGMAX 1GB 1066MHz @ 1040MHz, def.Voltage
* Power 300W, JNS !!! (ni da stucne, al bice zamenjeno danas-sutra za jache)
3Dmark03
def / 8600GTS clocks / MAX OC
3Dmark05
3Dmark06
def / 8600GTS clocks / MAX OC​
TESTOVI NA C2D MASINI & TESTOVI IGARA SUTRA-PREKOSUTRA.
:wave:​
Odlicna karta @ djwibe. Samo da poguras jos mako GPU i imaces extra rezove.
Pozdrav
Mogao bi i neke igrice da testiras,Bioshock,Airborne itd...inace karta je sjajna samo kad bi GPU isao malo vise :S:
Meni je na Gainward8600gt gs u bioshocku u rez 1280x1024 fps sa svim na max bio retkoo ispod 35, koliko palit postize?
odlicno
samo kad bi bilo da se kupi kod nas:trust:
opss nadjoh
izvinte ima u eurolinku
neznam koje si testove gledao ali ovo je sasvim dosta u odnosu na ostale
@djwibe
jel pstoji sansa da pogledas dali moze da se odradi V-mod po instrukcijama sa VR-zona ali ja mislim da je tamo obicna verzija ali proveri leba ti bio bih ti veoma zahvalan
Prvi rez na C2D mashini.
djwibe, sve pohvale! ;)
dizi taj gpu malo je 710 aj predji 13300 sa tom kartom
Da mogao bi da okacis testove nekih igara,ipak se to najvise ceni ;)
Imao sam problema koji sam sada resio pa evo rezova na golom Windowsu, bez CpuZ i ostalog (Posto cu instalirati opet Win, nisam instalirao nista sem samog sistema).
CPU@E2160-def. / GPU@def.
3Dmark03 17039
3Dmark05 9519
3Dmark06 5104
[email protected] / GPU@def.
3Dmark03 18483
3Dmark05 11306
3Dmark06 5590
[email protected] / GPU@710/2150
3Dmark03 21106
3Dmark05 12989
3Dmark06 6402
Potvrda samo za poslednji rez, bice jos toga.
Svaka cast :wave: ,zaista je sjajno da graficka koja kosta 110e ima skor 6402 u 3dmark06
WOW svaka čast! 8600GTS i x2600XT nemaju šta da traže pored ove kartice. Odlična kupovina!
Da rezultati su OK, jedino sto moj primerak izgleda da nece moci preko 710 za GPU, na moju zalost.
Izbacuje artifakte koje mozete da vidite ispod.
Inache karta ne zakucava ni na 750-760, ali u 3D modu (3Dmark) se pojavljuju artifakti (te crtice ispod na slici).
I OPET @ 730/2150​
3Dmark05=13179
napredujes jos samo malo pa eto 13.3k
svaka cast samo nastavi tako
I za kraj jos samo ovo. Odustajem od daljeg natezanja.
Palit je EXTRA karta, a C2D je chudo sta moze da odradi.
Palit 8600GT Sonic+
725MHz/2150MHz
3Dmark03=21705 / 3Dmark05=13380 / 3Dmark06=6576
@FXGT, sta sad kazes!:wave:
Zakljucak je da bar moj primerak stabilno preko 725MHz za GPU i 2150MHz za memoriju ne moze, ali i pored toga rezultati su vise nego dobri.
lepo a sto u vise tema pises jedno te isto
I ja cekam 9-ti,odlicna karta,mogli bi i neki rezultati u novijim igrama:d
Ja sam je narucio jos pre nedelju dana tj. pre dva petka. Valjda ce stici utorak, nadam se...
Stigao Palit i u moju masinu
Nema bolje karte za ulozen novac
Evo rezultat bez overkloka graficke
    54 KB · Pregleda: 328
