Postovane kolege!
Trebam savet u vezi postojece konfiguracije tj. mogucnosti da maksimalno iskoristim postojece audio kartice i ostali hardware.
Mislim da sam ovde najveci guster pa molim dzombe da mi pomognu!!!
Konfiguracija je sledeca:
Maticna ploca: Asus P5LD2 SE
http://www.asus.com/products4.aspx?l1=3&l2=11&l3=185&model=1022&modelmenu=1
Procesor: Core 2 Duo E4300 box
http://www.firingsquad.com/hardware/intel_core_2_duo_e4300_review/
Memorija: 1GB Kingston DDRII 667 (x2) znaci 2GB
http://www.newegg.com/Product/Product.asp?Item=N82E16820134045&ATT=20-134-045&CMP=AFC-C8Junction
HDD 1: Seagate 320GB S-ATA II
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=2268595
HDD 2: Maxtor 250GB S-ATA
http://www.pricegrabber.com/search_techspecs_full.php/masterid=3660409
Audio 1: Audigy 2 ZS Platinum PRO
http://www.creative.com/products/product.asp?category=1&subcategory=204&product=4925&nav=1
Zvucnici: Jazz Speakers J9906 (5.1) spojeni na Audigy 2
http://www.itsvet.com/proizvod/jazz-speakers-j9906/comp_tehn_speakers/133/86
Audio 2: E-MU 0404 PCI
http://www.creative.com/products/product.asp?category=237&subcategory=239&product=15760&nav=1
Graficka: ATI All-in-wonder X800XL sa 256MB
http://www.hothardware.com/viewarticle.aspx?articleid=737
Kuciste: Thermaltake Xaser III V1000+ 360W Silent Purepower
http://www.thermaltake.com/product/Chassis/fulltower/xaser3/1000plus.asp
Procesor za gitaru: ZOOM 505II Compact Multi Effects for Guitar
http://www.zoom.co.jp/english/products/505/index.php
Pitanja koja imam su sledeca:
0. Za Windows XP sp2 i optimizaciju necu pitati jer sam nasao savete oko toga...
1. Dali postojece audio kartice mogu raditi zajedno bez konflikata?
- Nikako da instaliram sistem a da mi obe kartice rade kako treba
2. Kako ili kojim redom instalirati kartice ili cak ostale komponente da bi sve radilo kako treba?
- Moguce da negde gresim oko redosleda pa mi zato jede dzigericu
3. Koje drajvere za audio kartice preporucujete?
4. Dali uradjen materijal pomocu 0404 moze verno biti reprodukvan kroz Audigy 2 karticu
- Nemam kinte da dokupim zvucnike koje bih nakacio samo na 0404...
5. Dali je pametno od 5.1 napraviti 2.1 (za Audigy) a ostala 2 satelita koristiti na 0404?
- Dali su ta 2 satelita od navodnih 50w dovoljna da prenesu pravi kvalitet...
6. Posto je All-in-wonder mnogo zeznuta za instalaciju, dali je moguce da na neki nacin smeta po pitanju muzicke produkcije?
- Spreman sam napraviti dual boot i razdvojiti sve ono sto smeta.
7. Dali je gotarski procesor ujedno i preamp i dali njegovim koriscenjem u snimanju gitare dobijam na kvalitetu?
8. Koje je najjeftijije zadovoljevajuce resenje oko preampa za mikrofon i koji je isto tako najjeftijiji zadovoljavajuci mikrofon?
Zahvalan sam za savete i pomoc svi vas koji se razumete mnogo. mnogo vise od mene!!!
Boki
Boki
