Oracle VirtualBox VM: Failed to load VMMR0.r0 (VERR_NO_MEMORY)
Broker
Pristup internetu
  1. Optički internet
  2. Kablovski internet
Pokušavam dapokrenem virtuelnu mašinu pod Oracle VirtualBox VM ali šta god da urdim dobijem ovo:
Failed to open a session for the virtual machine Home Assistant.
Failed to load R0 module C:\Program Files\Oracle\VirtualBox/VMMR0.r0: RTCrStoreConvertToOpenSslCertStore failed: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VMMR0.r0 (VERR_NO_MEMORY).
Failed to load VMMR0.r0 (VERR_NO_MEMORY).
Result Code: E_FAIL (0x80004005)
Component: ConsoleWrap
Interface: IConsole {872da645-4a9b-1727-bee2-5585105b9eed}
Log:
00:00:02.217277 VirtualBox VM 6.1.40 r154048 win.amd64 (Oct 11 2022 14:43:48) release log
00:00:02.217280 Log opened 2022-10-26T17:14:45.423146700Z
00:00:02.217280 Build Type: release
00:00:02.217282 OS Product: Windows 10
00:00:02.217283 OS Release: 10.0.17763
00:00:02.217283 OS Service Pack:
00:00:02.255671 DMI Product Name: To Be Filled By O.E.M.
00:00:02.259002 DMI Product Version: To Be Filled By O.E.M.
00:00:02.259010 Firmware type: UEFI
00:00:02.259411 Secure Boot: VERR_PRIVILEGE_NOT_HELD
00:00:02.259423 Host RAM: 32147MB (31.3GB) total, 26712MB (26.0GB) available
00:00:02.259425 Executable: C:\Program Files\Oracle\VirtualBox\VirtualBoxVM.exe
00:00:02.259425 Process ID: 7308
00:00:02.259426 Package type: WINDOWS_64BITS_GENERIC
00:00:02.260092 Installed Extension Packs:
00:00:02.260105 None installed!
00:00:02.260591 Console: Machine state changed to 'Starting'
00:00:02.260810 Qt version: 5.6.2
00:00:02.262360 GUI: UIMediumEnumerator: Medium-enumeration finished!
00:00:02.329484 PDMLdr: pdmR3LoadR0U: pszName="VMMR0.r0" rc=VERR_NO_MEMORY szErr="RTCrStoreConvertToOpenSslCertStore failed: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VMMR0.r0"
00:00:02.329498 VMSetError: F:\tinderbox\win-6.1\src\VBox\VMM\VMMR3\PDMLdr.cpp(733) int __cdecl pdmR3LoadR0U(struct UVM *,const char *,const char *,const char *); rc=VERR_NO_MEMORY
00:00:02.329504 VMSetError: Failed to load R0 module C:\Program Files\Oracle\VirtualBox/VMMR0.r0: RTCrStoreConvertToOpenSslCertStore failed: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VMMR0.r0
00:00:02.329515 VMSetError: F:\tinderbox\win-6.1\src\VBox\VMM\VMMR3\VM.cpp(567) int __cdecl vmR3CreateU(struct UVM *,unsigned int,int (__cdecl *)(struct UVM *,struct VM *,void *),void *); rc=VERR_NO_MEMORY
00:00:02.329516 VMSetError: Failed to load VMMR0.r0
00:00:02.329646 ERROR [COM]: aRC=E_FAIL (0x80004005) aIID={872da645-4a9b-1727-bee2-5585105b9eed} aComponent={ConsoleWrap} aText={Failed to load R0 module C:\Program Files\Oracle\VirtualBox/VMMR0.r0: RTCrStoreConvertToOpenSslCertStore failed: \Device\HarddiskVolume5\Program Files\Oracle\VirtualBox\VMMR0.r0 (VERR_NO_MEMORY).
00:00:02.329674 Failed to load VMMR0.r0 (VERR_NO_MEMORY)}, preserve=false aResultDetail=-8
00:00:02.329852 Console: Machine state changed to 'PoweredOff'
00:00:02.332042 Power up failed (vrc=VERR_NO_MEMORY, rc=E_FAIL (0X80004005))
00:00:02.832418 GUI: UIMachineViewNormal::resendSizeHint: Restoring guest size-hint for screen 0 to 800x600
00:00:02.832476 ERROR [COM]: aRC=E_ACCESSDENIED (0x80070005) aIID={4680b2de-8690-11e9-b83d-5719e53cf1de} aComponent={DisplayWrap} aText={The console is not powered up (Display::setVideoModeHint)}, preserve=false aResultDetail=0
00:00:02.832685 GUI: Aborting startup due to power up progress issue detected...
To mi se dešava samo na ovom računaru. Radio sam ovo na drugim računarima i nije bilo problema.
Zna li neko šta može biti uzrok?
