Open SUSE 10 & 9600 problem
einstein
Instaliran je Open SUSE 10, graficka je 9600. Ne mogu da instaliram drajvere koje sam skinuo sa interneta (xwindows-xorg). Daje gresku pri kompajliranju. Isti radili na 9.2.
Skini sa ATI-jevog sajta i instaliraj na sledeći način:
Create a RPM for SUSE 10.0 (i386) by using the installer.
./ati-driver-installer-8.20.8-i386.run --buildpkg SuSE/SUSE100-IA32
Afterwards install the created RPM by using the rpm command. In the
mentioned example above this would be:
rpm -Uhv fglrx_6_8_0_SUSE100-8.20.8-1.i386.rpm
The postinstall script of this RPM will try to compile the required
kernel module. If this fails, you'll get a message how to proceed.
You still need to configure the driver with SaX2. Details can be found
in /usr/share/doc/packages/fglrx/README.SuSE.
Unfortunately you need to recompile the "fglrx" kernel module right
after any kernel (security) update. Use "fglrx-kernel-build.sh" for
this.
Kod mene radi (OpenSuse 10 Eval, Radeon 9550).
Provereno rade na 9550.
Ili nisi pazljivo pratio uputstva sa sajta, ili te zeza gcc.
Pre ce biti ono prvo.
RTFM!
