Omega 2.5.04
voodoo_
Je li, po chemu su ovi drajveri "optimizovaniji" od zvanichnih? Koliko sam uspeo da primetim u ovih nekoliko dana korishcenja, bazirani su na Katalistima 3.1, a rade isto kao oni... pa gde je sva ta optimizacija? Shto sam dzabe skidao 15.7 MB???
Pojma nemam koje su optimizacije uvrstene ali ja sa tim omega drajverima dobijem uvek par stotina markova vise...
xvoodoo je napisao(la):
...What's New? (2.5.04 / 2.5.29)
* Based on the Official Catalyst 3.10 drivers. (2k/XP/9x/ME)
* Fixed the setup issues once and for all by re-writing the ATI setup INIs from
scratch. This was tested on a LOT of cards and they worked perfectly, if you
still have problems please E-Mail me.(2k/XP/9x/ME)
* Updated the profiler utility to the latest version with OC support
included. (2k/XP)
* Removed RadClocker from the package (petition by the author). (2k/XP/9x/ME)
* Added the STRETCH screen option for Digital Flat Panel monitors and
laptops. (2k/XP/9x/ME)
* Added support for HDTV resolutions. (2k/XP/9x/ME)
* Changed some of the default Omega settings. (2k/XP/9x/ME)
* Fixed the Dual Monitor/ATI Control Panel problems. (2k/XP/9x/ME)
* Added 1400x1050@60Hz for FPD monitors and laptops. (2k/XP/9x/ME)
:wave;
meaculpa je napisao(la):
Da ne bude zabune, ovo sto si naveo su razlike izmedju dve verzije Omega a ne izmedju Omege i zvanicnih, sto je xvoodoo pitao.
1. ove opcije mi nisu od nikakve koristi...
2. ko shto reche drapin, mene interesuje razlika izmedju Omege (bazirane na cat3.1) i pravih cat3.1, poshto koliko primecujem rade isto...
mislim, kad sam vec brisao zvanichne 3.9 koje sam koristio, mogao sam da vratim zvanichne 3.1, a ne da skidam ove for nothing...
sve te "dobijene" performanse sam imao i sa spomenutim zvanichnim katalistima 3.1...
