Omega 2.4.43 (catalyst 3.4 based) drajveri spremni
Bane-Nis
Jeeeeeeee! I nalaze se vec u download sekciji sajta omegacorner.com!
What's New?
** Merged both Win9x/ME and Win2k/XP readme files since the changes
made to both are basically the same, except when specified.
* Based on the official Catalyst 3.4 ATI drivers. (9x/ME/2k/XP)
* Added support for the following chipsets: (9x/ME/2k/XP)
Radeon 9200
Radeon 9200 Pro
Radeon 9800
Radeon 9800 Pro
* Removed names for specific cards (Tyan, Gigabyte, etc.),
now they all have a common name (9700, 9500, etc.) (9x/ME/2k/XP)
* Removed support for Mobility cards in the 2k/XP drivers, those
of you that need support for mobility cards please use Patje's
Mobility Modder utility to add support. The utility can be found
here: http://www.driverheaven.net/patje/
* Updated all included utilities to most recent versions. (2k/XP)
* Added an Overclocking utility for all cards, can be found
in the ATI Control Panel, it's a new tab. (2k/XP)
* Added the Advanced SmartGart options, can be found in the folder
created by my drivers in the Start Menu. (9x/ME/2k/XP)
* The 9500->9700 and 9700->9800 hack is included and can be selected
during the installation process, but now is better explained,
easier for newbies. (9x/ME/2k/XP)
* The installer has been updated with more acurate information on all
the areas, including the readme and options description. (9x/ME/2k/XP)
Koje su prednosti koriscenja Omega drajvera u odnosu na "konvencionalne" ATi drajvere...Skinuo sam prethoden Omega drajvere (bazirane na Catalystima 3.2) i nisam primetio neke razlike...NIsam se bas nesto udubljivao u problematiku, a i od skoro sam na ATi-ju (od Catalista 3.2 :) )
Inace, advanced smartgart opcije se lako mogu dobiti na start/run - "smartgart" - enter :)
delimir je napisao(la):
Kompatibilnost sa igrama. Recimo na GA9000Pro u C&C Generalsu sa Catalyst-ima se jedinice ne vide ! Mozes da ih oznacis ali one se ne vide na ekranu. Sa Omeginim drajverima sve sljaka super. Tako je bilo sa 3.1. Za dalje revizije ne garantujem.
Meni Generalsi rade dobro (Cat3.2 & Cat3.4 takodje GA R9000Pro)...
Kao sto rekoh, to je vazilo za Kataliste 3.1, taman posla da to dosada nisu ispravili, zasto bi i izbacivali nove drajvere.
Nego kad smo vec kod ovih drajvera, je li probao neko kakva poboljsanja donose (ako donose) u brzini na 9500 Pro kartama ?
