NZXT Beta EVO - budget gaming case
Jovyland
VIP član
CPU & Cooler
Ryzen 5 5600
Matična ploča
MS B350M Mortar Arctic
RAM
16GB DDR4 HyperX 3200Mhz
GPU
XFX Qick RX 6700XT
Storage
1 TB SSDa + 3TB HDDa
PSU
Seasonic MII EVO 520W
Monitor
DELL G2724D
Laptop
HP Pavilion Aero 13
Steam
jovyland
Pristup internetu
  1. Optički internet
  2. Mobilni internet
EVO je naslednik odlicnog NZXT Beta kucista, a od njega se razlikuje po mestu za napajanje koje je sada smesteno na dnu, mnogo boljim mogucnostima za cable managment i dva dodatna otvora za 12-ice na vrhu. Cena kucista bi trebala da bude ista kao i kod "starijeg" modela, odnosno ~60 evra kod nas. Da bi cenu zadrzali na sto nizem nivou, kuciste ce se isporucivati bez fanova, za razliku od Beta koja dolazi sa samo jednim, pa je dodatno investiranje u bar dve 12-ce pozeljno. I ovako, kuciste predstavlja best buy u ovom cenovnom rangu, a tu je i black-painted enterijer. U prodaji ce se naci od septembra.
BETA EVO Classic Series
Mid tower black steel chassis
Announcing the Beta EVO, a sleek, all black value packed mid tower case at a budget price. Beta EVO features advanced cooling performance with support for up to 6 120 mm fans with an option of a 140mm fan at the top. Beta EVO also provides external dual radiator support along with a meshed front panel allowing for enhanced cooling potential.
Full of options for expansion, the case fits high performance 10.5” graphics cards, up to 4 external 5.25” drives and 5 internal 3.5” HDD racks. Beta EVO provides a number of features that significantly enhance ease of installation including screwless installation for 5.25” drives and superior wire management capabilities with the bottom mounted PSU and 180° turned HDD cage. It also features punched holes in the motherboard allowing for quick CPU bracket removal.
Features
  • Fits ATX Standard Motherboards and Power Supplies
  • Fits large 10.5” performance graphic cards
  • Expanded cooling directly cools video cards and CPU
  • Support for up to 6 120mm fans with the option of dual 140mm at the top
  • Screwless installation for hard drives and external 5.25” drives
  • Black Internal finish for sleek look
  • Meshed front panel allows for better airflow than traditional cases
  • Superior wire management with bottom mounted :: PSU and CPU punchout for heatsink removable
  • Removable PSU filter
  • 180 degree Turned HDD for a cleaner internal finish and better wire management
  • External Dual radiator support
  • Top mounted USB/Audio for convenient usage
http://www.nzxt.com/products/beta_evo/
http://www.nordichardware.com/news,9739.html
http://www.hardwaresecrets.com/news/4104
Moram priznati da izgleda vrlo ozbiljno. Ne znam kakvog je kvaliteta (dok ne opipam ne verujem) ali u svakom slucaju je vredno paznje.
Prvi review 10/10 :)
Hladjenje i cable managment su odlicni.
Performance
The NZXT Beta EVO performed outstandingly, especially for the price point, with superb functionality to boot. The temperature of the system was close to room temperature, with only a one degree rise under load. The provisions for additional cooling fans are a nice touch for the price point and gives more than enough airflow through the case, even with two dual GPU graphics cards within the system. The screw less design functioned very well, allowing quick tool less drive installs and changes, making the installation of the system very simple.
Reviewer's Opinion
The NZXT Beta EVO is a great case to build a system around, especially if you are on a budget, but don’t want to sacrifice on the capabilities of the case. The tool less design is a great feature that tends to be something more associated with higher dollar cases. The excellent ventilation also proves to be an exception to the rule for cases of this price point. Though the case only comes with one fan installed, the ventilation alone proved to be great when looking at the case’s overall performance. In many instances, a case in this price point normally tends to suffer from a lack of ventilation and fans, with noticeably higher then ambient system temperatures. This just is not the case with the Beta EVO, which really helps to push this case above the rest for an excellent case at a very affordable price.
Pros
Performance
Excellent ventilation
Plenty of optional fan locations
Exceptional cable management
Tool less drive installation
Cons
none
PureOC Review
Summary
Simply because a case is being marketed as budget does not mean that it is of budget quality. The Beta EVO arrived as a fully featured mid tower, performed as such, but is priced as though it is something substantially less. Featuring water cooling capability, plenty of spaces through which wires may be routed and plenty of fan spaces, this is a beast of a case, and you can't forget the interior paint.
As a mobile mid tower, the Beta EVO features the aesthetics and wiring potential to keep your machine looking great. While it doesn't stand out as boldly as other cases, it does not sacrifice utility or performance to achieve the aesthetic appeal it has.
The slightly bent tab above the PSU was a small gripe, not a big one. I'm also disappointed with only 1 fan being included, but I suppose that this would put it into another price bracket. I honestly can't think of much that is wrong with this case. The main chassis is sturdy, it is pretty roomy.
Priced at about $60 USD, this case is a deal like no other, and better than many cases I've used that cost $30 more in both looks and utility. All these wire routing options (can't stop mentioning them, they're so great!), and no need for a Dremel! It can easily trump many other cases in its price segment, and even some above it. Probably not the best buy if your main concern is computer pimping, but it is definitely the best buy if nearly anything else has an influence on your selection.
Cekajte ljudi, pa kod nas odavno ima NZXT BETA black Metal Ed. koji se razlikuje jedino sto nema na vrhu mesta za fenove, ili nesto propustam?
Znači ima razlike između Black Metal ed. i ovog iz ove teme?
Aha, sad sam i ja proverio na njihovom sajtu.
Jos par testova:
http://www.overclockersclub.com/reviews/nzxt_beta_evo/
http://www.hardwaresecrets.com/article/830
http://www.neoseeker.com/Articles/Hardware/Reviews/nzxt_evo_review/
http://www.nzxt.com/reviews/beta_evo
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/dzTqni41C9o&hl=en&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/dzTqni41C9o&hl=en&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Ima li ga kod nas?
I jel se pojavio EVO kod nas?
Nije, a verovatno i nece.
[YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/wiXDgIMZ1sk&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/wiXDgIMZ1sk&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE] [YOUTUBE]<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/lp_McihazXk&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/lp_McihazXk&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>[/YOUTUBE]
veoma zanimljivo kuciste, mada mi se nesto ne svidjaju resenja oko dust filtera.
dobro izgleda ali je meni tempest evo mnogo lepsi:)
koliko ce ovo da kosta kod nas?
