Mare
NV30;
400MHz GPU - 8 pipeline engine - .13Micron
512-bit architecture
800~1000MHz DDR / QDR memory
400MHz Ramdac
LMA3 on 128MB~256MB Video Memory.
DirectX9 - OpenGL 1.3
NV35;
500MHz GPU - 8 pipeline engine - .13Micron
1000~1200MHz DDR / QDR memory
400MHz Ramdac
TT&L Technology
DirectX 9.1 - OpenGL 2.0
I'll go through these GPUs in a bit of detail with everyone,
-First, the NV30 is a brand new architecture. That means no more GeForce title, and no more internal guts which were repeated all the way through the GeForce architecture.
-The GeForce 4 was 256-bit, while the NV30 is 512-bit.
-The GeForce 4 was built on .15Micron technology while the NV30 is built on .13Micron Technology.
-GeForce4 is limited to 4096x4096 texture sizes while the NV30 has an infinite maximum texture size meaning 16384x16384 and higher can now be possible.
-NV30 also supports future resolutions of up to 2560x1920 with 64-bit colour (These are 100% rumors, so dont be let done if the final product doesnt support 64-bit colour). The whole rumor of 64-bit started when John Carmack back almost two years ago opened his mouth about Doom3's 64-bit support through the help of next generation Nvidia architecture.
-GeForce 4 features AGP4X while NV30 has full AGP8X support.
-NV30 supports memory bandwidth up to 16GB/s (1GHz).
-PCI-X support (1GB/s) the advanced PCI interface thats an alternative to AGP8X (2GB/s).
-This product is expected to be annouced in August 2002 and is expected to hit store shelves by late september, early october.
As the CEO announces this wonderful new revolutionary GPU advancement, consumers countinue to purchase inferrior products such as GeForce4.
key new NV35 features:
-NV35 will hit the 500MHz barriar on .13Micron technology. To do this Nvidia is removing the T&L unit from the GPU and putting it external. This allows for more heat spreader and better heat transfer from the GPU.
-By removing the T&L unit, Nvidia is building on a new technology called TT&L which runs at 3/2 the GPU speed. (EX: Your GPU ran at 200MHz, the T&L unit would run at 300MHz) In NV35 case, the T&L unit will now run dedicated at 750MHz.
-Expected memory bandwidth of the NV35 is between 20~24GB/s.
-3DFX SLI technology will be implemented in higher models (A.K.A Workstation models)
-This product is expected to be annouced in January 2003, shipping by March.
Pogledajte efekat 3dfx inzenjera posebna T&L jedinica na 750 MHz!!!!
Eee, to je vec nesto!!!
boom boom boom boom boom boom boom
