Nepoznat razlog restartovajna racunara
linama13
Poštovan
S' vremena na vreme ni se restartuje racunar.
Antivirus kaze da je sve 0k.
U log fajlu sam nasao ovo. Zna li neko u cemu je problem
GENERAL
Faulting application name: rundll32.exe, version: 10.0.19041.746, time stamp: 0x60362c8f
Faulting module name: ntdll.dll, version: 10.0.19041.844, time stamp: 0xa9ac4e88
Exception code: 0xc0000005
Fault offset: 0x00072bbc
Faulting process id: 0x1254
Faulting application start time: 0x01d715a1e05d58ce
Faulting application path: C:\WINDOWS\SysWOW64\rundll32.exe
Faulting module path: C:\WINDOWS\SYSTEM32\ntdll.dll
Report Id: a98d1b1a-6dad-40bb-968e-4d5a320453eb
Faulting package full name:
Faulting package-relative application ID:
DETAILS
-System
-Provider
[ Name] Application Error
-EventID1000
[ Qualifiers] 0
Version0
Level2
Task100
Opcode0
Keywords0x80000000000000
-TimeCreated
[ SystemTime] 2021-03-15T13:23:38.8979288Z
EventRecordID12689
Correlation
-Execution
[ ProcessID] 0
[ ThreadID] 0
ChannelApplication
Computeri
Security
-EventData
rundll32.exe
10.0.19041.746
60362c8f
ntdll.dll
10.0.19041.844
a9ac4e88
c0000005
00072bbc
1254
01d715a1e05d58ce
Instaliraj Whocrashed i pritisni Analyze.
Testiraj memoriju sa Memtest86, par ciklusa.
Napiši koje su komponente i OS. Da li se restartuje pri određenim aplikacijama ili slučajno?
MB Biostar BT 250 BTC
CPU Intel G4560
RAM 4 gb ADATA
6 x Radeon RX 580 8 gb XFX
HDD KINGSTON SA400S37120G
2 x Chiftec ELP-700S
Crash Dump Analysis
Crash dumps are enabled on your computer.
Crash dump directories:
C:\WINDOWS
C:\WINDOWS\Minidump
On Wed 2/24/2021 8:02:32 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\022421-17890-01.dmp
This was probably caused by the following module: bsmem.sys (0xFFFFF80445E73882)
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF80445E73882)
Error: DRIVER_IRQL_NOT_LESS_OR_EQUAL
file path: C:\WINDOWS\system32\drivers\bsmem.sys
product: BIOSTAR I/O driver fle
company: BIOSTAR Group
description: I/O Interface driver file
Bug check description: This indicates that a kernel-mode driver attempted to access pageable memory at a process IRQL that was too high.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: bsmem.sys (I/O Interface driver file, BIOSTAR Group).
Google query: bsmem.sys BIOSTAR Group DRIVER_IRQL_NOT_LESS_OR_EQUAL
crash dump file: C:\WINDOWS\MEMORY.DMP
On Wed 2/24/2021 7:58:48 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\022421-17640-01.dmp
This was probably caused by the following module: bsmem.sys (0xFFFFF80228FD3882)
Bugcheck code: 0xD1 (0x0, 0x2, 0x0, 0xFFFFF80228FD3882)
On Mon 2/8/2021 11:34:11 AM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\020821-19609-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x3F5780)
Bugcheck code: 0x9F (0x3, 0xFFFFA28DF553B060, 0xFFFFF8052AED2850, 0xFFFFA28DF98F7520)
Error: DRIVER_POWER_STATE_FAILURE
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This bug check indicates that the driver is in an inconsistent or invalid power state. A device object has been blocking an IRP for too long a time.
This is likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
On Thu 2/4/2021 2:40:02 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\020421-20140-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFCA076A6BE290, 0xFFFF890FFC837850, 0xFFFFCA076EAF5A30)
On Wed 2/3/2021 6:19:58 PM your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\020321-18968-01.dmp
Bugcheck code: 0x9F (0x3, 0xFFFFD68BB13AC060, 0xFFFFF806542D2850, 0xFFFFD68BBD373A30)
Conclusion
6 crash dumps have been found and analyzed. A third party driver has been identified to be causing system crashes on your computer. It is strongly suggested that you check for updates for these drivers on their company websites. Click on the links below to search with Google for updates for these drivers:
If no updates for these drivers are available, try searching with Google on the names of these drivers in combination with the errors that have been reported for these drivers. Include the brand and model name of your computer as well in the query. This often yields interesting results from discussions on the web by users who have been experiencing similar problems.
Read the topic general suggestions for troubleshooting system crashes for more information.
Note that it's not always possible to state with certainty whether a reported driver is responsible for crashing your system or that the root cause is in another module. Nonetheless it's suggested you look for updates for the products that these drivers belong to and regularly visit Windows update or enable automatic updates for Windows. In case a piece of malfunctioning hardware is causing trouble, a search with Google on the bug check errors together with the model name and brand of your computer may help you investigate this further.
