Od pre dva dana imam problem sa ucitavanjem jednog foruma, koji sam dotle
normalno posecivao bez problema.
U pitanju je :
Kod:
http://forum.coper-srbija.com/index.php
Stalno mi izbacuje :
The connection has timed out
The server at forum.coper-srbija.com is taking too long to respond.
The site could be temporarily unavailable or too busy. Try again in a few
moments.
If you are unable to load any pages, check your computer's network
connection.
If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
Iskljucivao sam firewall i antivirus, odradio ipconfig /flushdns, dodao sam rucno OpenDNS i Google DNS, pokusao sa dodavanjem IP adrese u hosts file Wina , resetovao ruter (ADSL ruter). Probao sam i sa par drugih sajtova koji su na istoj IP
adresi i oni nece da se ucitaju. Kao da je ceo opseg IP adresa blokiran :wall:
Ono sto je zanimljivo je da preko proxy-a uspevam da ucitam forum ali ne mogu nista da postujem, samo citam postove.
Ako imate neki predlog sta da radim pisite !
