i Image tj. Ghost Win XP 64bit bez scsi-ja. Samo hocu da instaliram New Hardware SCSI kontroler i da radi, ako je moguce?
a koji je to bas ovaj?
zato sto stvarno ne vidim kako nece - drajver je veliki preko 250kb i ima citavih 3 fajla(naravno raspakovan i za 64bit verziju windowsa):3.10. Installing the Driver when Windows XP is Already Installed
1) Physically install the Ultra320 adapter and boot up the
system. Windows will automatically discover the new
hardware and start the Found New Hardware Wizard.
2) Choose the "Install from a list or specific location"
option and click Next.
3) Insert the Adaptec Ultra320 FMS driver disk into the
floppy drive, check the "Include this location in the
search" option, type in "a:\Win32bit" and click Next.
If you are installing on a 64-bit system, type in
"a:\Win64bit" and click next.
4) At this point you may be prompted with a warning message
that the driver has not passed Windows Logo testing.
Ignore this message if it appears and click "Continue
Anyway".
5) When the driver is copied on the hard drive, click
Finish.
6) You may be required to restart the computer at this
point.
7) If you are installing a dual channel adapter, the Found
New Hardware Wizard will restart. Choose the option
"Install the software automatically" and follow the
instructions. Again, you may be required to restart
your computer.
