leonedanieli
Poštovan
Hej, drustvo, nov sam na forumu, ali sam u IT vodama od sredine 90-tih.
Imam komp za print dizajn (plus mjuz, viber, web) i malo mi je spor, pa bih hteo da ga upgrade-ujem ili da kupim nov.
Jako sam slab sa hardverom (poznavanje 0), pa bih vas molio za pomoc.
Skinuo sam CPU ID program i ovo je izvestaj mog kompa:
Drive 0
Name Samsung SSD 850 EVO 250GB
Revision EMT02B6Q
Serial S2R6NX0HC75605F
Capacity 232.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Features SMART, TRIM
Volume c:\, 231.9 GBytes (79.3 percent available)
Drive 1
Name TS64GSSD370S
Revision N1114H
Serial C364433891
Capacity 59.6 GB
Type Fixed, SSD
Bus Type SATA (11)
Volume f:\, 59.2 GBytes (61.6 percent available)
Drive 2
Name ST1000DM003-1ER162
Revision CC46
Serial Z4Y7ELSE
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Rotation speed 7200 RPM
Features SMART
Volume d:\, 443.1 GBytes (81.4 percent available)
Volume e:\, 488.3 GBytes (33.7 percent available)
Socket 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Pentium G3250
Codename Haswell
Specification Intel(R) Pentium(R) CPU G3250 @ 3.20GHz
Package (platform ID) Socket 1150 LGA (0x1)
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
TDP Limit 53.0 Watts
Tjmax 100.0 °C
Core Speed 3199.3 MHz
Multiplier x Bus Speed 32.0 x 100.0 MHz
Base frequency (cores) 100.0 MHz
Base frequency (ext.) 100.0 MHz
Stock frequency 3200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T, VT-x
CPU-Z version 1.87.0.x64
Chipset
Northbridge Intel Haswell rev. 06
Southbridge Intel H81 rev. C2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR3
Memory Size 16 GBytes
Channels Dual
Memory Frequency 666.5 MHz (1:5)
CAS# latency (CL) 9.0
RAS# to CAS# delay (tRCD) 9
RAS# Precharge (tRP) 9
Cycle Time (tRAS) 24
Row Refresh Cycle Time (tRFC) 174
Command Rate (CR) 1T
Uncore Frequency 3199.3 MHz
Host Bridge 0x0C00
DMI Processor
manufacturer Intel
model Intel(R) Pentium(R) CPU G3250 @ 3.20GHz
clock speed 3200.0 MHz
FSB speed 100.0 MHz
multiplier 32.0x
DMI Physical Memory Array
location Motherboard
usage System Memory
correction None
max capacity 32 GB
max# of devices 4
DMI Memory Device[/B]
designation ChannelA-DIMM0
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 8 GB
DMI Memory Device
designation ChannelB-DIMM0
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 8 GB
Hocu da je brzi, jaci, bolji :d
Da li je dovoljno kupiti SAMO procesor, kako mi rece kolega ili jos nesto ili potpuno nov?
Hvala puno! :type:
Drive 0
Revision EMT02B6Q
Capacity 232.9 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 1
Name TS64GSSD370S
Revision N1114H
Serial C364433891
Capacity 59.6 GB
Type Fixed, SSD
Bus Type SATA (11)
Drive 2
Revision CC46
Serial Z4Y7ELSE
Capacity 931.5 GB
Type Fixed
Bus Type SATA (11)
Features SMART
Socket 1 ID = 0
Codename Haswell
CPUID 6.C.3
Extended CPUID 6.3C
Core Stepping C0
Technology 22 nm
Tjmax 100.0 °C
Chipset
Memory Type DDR3
Channels Dual
Host Bridge 0x0C00
DMI Processor
manufacturer Intel
FSB speed 100.0 MHz
multiplier 32.0x
usage System Memory
correction None
max capacity 32 GB
max# of devices 4
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 8 GB
DMI Memory Device
format DIMM
type DDR3
total width 64 bits
data width 64 bits
size 8 GB
Hvala puno! :type:
