bolkonski je napisao(la):Au, mislio sam sta treba instalirati na XP od programa da bi ovaj dobro radio.
kUdtiHaEX je napisao(la):Covek je mislio na klasicne programe za XP - tweak programi, programi za promenu izgleda XP-a i sl.....
septimus je napisao(la):Ajde da postavimo poll : "SHTA JE PISAC HTEO DA KAZE..." Octp;
majka je napisao(la):moja preporuka: samo tweak UI a zatim step by step uputstvo sa www.videoguys.com
neke stvari mozda treba izostaviti zbog specificnosti sopstvenih potreba...
ali treba osetiti tu razliku cistog xp-a pre i posle ovog postupka...nebo i zemlja zaista...
i nije neki savet. Svi mi znamo da treba da instaliramo drajvere koji su za XP (ako drzimo XP jelMake sure you have Win XP drivers for ALL your hardware and software.
The key word here is ALL. It only takes one outdated or not ready for XP driver to kill your XP systems performance. Worse yet, you could crash or lock up. You really want to do your homework BEFORE you install XP. Here are a few steps that will take some time, but save you hours of frustration in the long run:
Go to your motherboard vendor's website and make sure you are running a chipset and BIOS that will support XP.
If necessary update your BIOS before doing anything else.
Make sure your graphics, sound, network, mass storage controller and modem all have WinXP drivers. Get these drivers from the Vendors websites directly. We do not recommend letting WInXP install it's own drivers. These may be fine for websurfing and spreadsheets, but desk top video demands maximum performance.
Get your system up and running with ALL drivers approved for XP.
Get the latest WinXP drivers for your video editing gear.
If there isn't an official driver for XP yet, check and see how other users are gettting along with the old Win2K driver or new XP beta drivers. Only experienced users should try this.
kUdtiHaEX je napisao(la):...
i nije neki savet. Svi mi znamo da treba da instaliramo drajvere koji su za XP (ako drzimo XP jel)....
majka je napisao(la):...
mozda nisi dobro video[guys]...
probaj ponovo...
http://www.videoguys.com/TweaksWINXPVE.html
