Imam problem sa podesavanjem MSI BToes-a za izlaz na internet preko GPRS-a. Imam Siemens S55 i Win2k i MTS064 Prepaid. Uredjaj sam instalirao i komunikacija sa telefonom je ok. Podesio sam sve parametre sa Telekom sajta ali kad pokusam da se konektujem javi mi sledece:
Veryfaing username and password... (ok)
Registering your computer on the network
Error 734: The PPP link control protocol was terminated
Info:
"734
A PPP link control protocol conversation started, but terminated at the request
of the remote computer. An error probably occurred on the server. See your system administrator.
Also, your system administrator can enable PPP logging by using the Netsh.exe utility, which may
help to identify the PPP negotiation problem."
Inace sam prethodno, telefon povezao preko IrDa na Toshiba Laptop-u sa WinXP i bez problema izasao na internet, tako da pretpostavljam da je u telefonu sve podeseno kako treba.
Da li neko zna sta treba jos podesiti?
Info:
"734
