MSI Reminds You...
• According to the Intel North Bridge 945PL chipset spec, this board supports CPU of FSB 800MHz at maximum by default . However, you may let your board running at FSB 1066MHz (Core 2 Duo CPUs) by overclocking and adjusting the CPU FSB frequency in the BIOS:
Enter BIOS setup menu and go to [Cell_Menu] --> [Adjust CPU FSB Frequency]. There you can adjust the value to [266] for the Core 2 Duo E6300/E6400/E6600/E6700 CPUs. Please be noted that this is over-spec, and this overclocking behavior is not recommended and guaranteed.
*This is for PCB 2.2 only.
Offtopic: A sto u forum "Graficke"?
Mislim, ali nemoj da me drzis za rec, da E2160 nije C2D, nego dualcore Pentium (Conrole-L).
Realno je ocekivati fsb od 266 MHz, to ces 99% uspeti, za preko ove granice ne znam, nisam probao.
Super probaj pa daj izvestaj sta ste postigli posto i mene zanima konfiguracija sa tom plocom i 2160. BTW ima neko savet za neku jeftiniju plocu koja moze preko 300 fsb sa ovim procesorom?OK, hvala. Videcemo sutra kad drugaru stigne CPU, sta mozemo izvuci iz komponenti.![]()
