MPC--Project Cowbell
xSeptimus
VIP član
Modifikovani MPC, neke sitnice su prepravljene. Posebno one koje su smetale kod
playliste... http://www.geocities.com/projectcowbell/pcbprog.zip
. Numerous new play list window context-menu items, including options to browse for files to add, clear the list, remove invalid items and crop to selected items (pictured to the left)
· A “Find Media” feature (pictured above) that allows for the efficient navigation and management of medium to large sized lists, accessible via the F3 key, or the play list context menu
· Option to remember your last play list when the player starts
· Multi-file selection in the play list
· A menu item to enable/disable play list repeat
· Random play mode that doesn’t shuffle the play list
· Option to not stop playing the current item if it is removed from the play list
· Option to proceed directly to the browse dialog from the File->Open command
· Auto-hiding of docked play list in full-screen mode
· Option to automatically hide an undocked play list when entering full-screen mode
· Scrolling the mouse wheel while holding the right mouse-button seeks backwards or forwards by a user-defined increment
· Many more minor modifications
....... koji je totalno nebitan , valjda gledas video a ne program ?!
zoni, evo ti napravi skin kako hoces da program izgleda, ja cu napraviti program koji ce preko girdera ili direktno da kontrolise mpc |]
ZoNi je napisao(la):
...mada, kad sa BS-a predjem na MPC, sve deluje malo zastarelo...
ma da, a da ne govorimo kako BSPlayer izgleda kao rezultat tutorijala u Visual Basicu 6... 😉
uf... tu se nikako ne slazem!
vidi moj omiljeni BSP skin:
i jos:
http://www.bsplayer.org/upload/skins/preview/Winamp5 skin for BSPlayer.zip.thumb.jpg
http://www.bsplayer.org/upload/skins/preview/dRL_Real_iTunes.bsz.thumb.jpg
http://www.bsplayer.org/upload/skins/preview/MacLightV1.4.bsz.thumb.jpg
Pokushaj precizno da premotash film na neki deo, pa ce ti biti jasno zashto je mpc bolji onako 'ruzan' 🙂
Voodoo_NBGD je napisao(la):
Ispravka: kao LOS rezultat jos GOREG tutoriala u VB 6 🙂
