MicroStar 6163 PRO
MiskoZ
Koji je najjachi procesor koji bi mogao da ide na ovu plochu?
Pa svi Celeroni sem ovih sa Tualatin jezgrom, Coppermine takodje...Sirok dijapazon sigurno, ali najbolje da pogledas na MSI sajtu.
Sto se tice Celerona verovatno svi na FCPG adapteru, znaci zakljucno sa 1100 (...850,900,950,1100R), ovi novi T.ne mogu (doduse neko rece da postoji adapter i za njih ali se verovatno ni blizu ne isplati).
MS-6163 Pro CPU Support Status
revision: 2.0C with BIOS version: 3.A
is currently validated for the following processors:
Note that only the highest speed is shown. If not otherwise indicated, the lower speed processors have already been validated.
Intel Celeron A (Slot 1) 500MHz
Intel Celeron A (FPGA 370) 533MHz
Intel PII (Klamath, Slot 1) 300MHz
Intel PII (Deschutes, Slot 1) 450MHz
Intel Celeron (w/o Cache, Slot 1) 300MHz
Intel Celeron II (Coppermine, FCPGA, FSB 66) 700MHz
Intel Celeron II (Coppermine FCPGA) 800MHz
Intel PIII (Katmai, Slot 1, FSB 100) 600MHz
Intel PIII (Coppermine, Slot 1, FSB 100) 850MHz
Intel PIII (Coppermine, Slot 1, FSB 133) 866MHz [overclocking]
Intel PIIIE (Coppermine, FCPGA, FSB 100) 850MHz
Intel PIIIEB (Coppermine, FCPGA, FSB 133) 1000MHz
pozdrav....
