E ovo je ta prica a posto nisam bas englez moracu nekog da zovem upomoc .!
Preinstalling Microsoft HD Audio Class Driver 1.0a Out Of Band (OOB) Release KB888111
Part of the Universal Audio Architecture initiative
Readme Document
January 17th, 2004
Information in this document, including URL and other Internet Web
site references, is subject to change without notice and is provided
for informational purposes only. The entire risk of the use or
results of the use of this document remain with the user, and
Microsoft Corporation makes no warranties, either express or implied.
Unless otherwise noted, the example companies, organizations,
products, people, and events depicted herein are fictitious. No
association with any real company, organization, product, person,
or event is intended or should be inferred. Complying with all
applicable copyright laws is the responsibility of the user. Without
limiting the rights under copyright, no part of this document may
be reproduced, stored in or introduced into a retrieval system, or
transmitted in any form or by any means (electronic, mechanical,
photocopying, recording, or otherwise), or for any purpose, without
the express written permission of Microsoft Corporation.
Microsoft may have patents, patent applications, trademarks,
copyrights, or other intellectual property rights covering subject
matter in this document. Except as expressly provided in any written
license agreement from Microsoft, the furnishing of this document
does not give you any license to these patents, trademarks,
copyrights, or other intellectual property.
(c) 2004 Microsoft Corporation. All rights reserved.
Microsoft, MS-DOS, Windows, and Windows NT are either registered
trademarks or trademarks of Microsoft Corporation in the United States
and/or other countries or regions.
The names of actual companies and products mentioned herein may be
the trademarks of their respective owners.
How to Use This Document
To view the Readme file in Microsoft Windows Notepad, maximize
the Notepad window. On the Format menu, click Word Wrap.
To print the Readme file, open it in Notepad or another word
processor, and then use the Print command on the File menu.
Preinstalling HD Audio OOB
This document provides instructions for preinstalling the 1.0a UAA HD AUdio OOB KB888111 release
Windows 2000 SP4, Windows XP SP1, Windows XP SP2 and Windows Server 2003 Gold. This release does not install on Server 2003 SP1.
You can preinstall the UAA HD Audio OOB only on the above mentioned operating systems.
Do not preinstall the UAA HD Audio OOB on Windows 2000 without Service Pack 4
installed, or the original "gold" release of Windows XP, or on any version of
Windows XP 64-Bit Edition OS SKUs.
The preinstall reuires a reboot on Windows 2000 SP4 and on the other operating systems
as well if the OS component Portcls.sys is in use during the installation (another audio driver was loaded
prior to the Microsoft HD Audio package install).
There are four main packages, all available in 24 different languages.
KB888111w2ksp4.exe - supports Windows 2000 SP4
KB888111xpsp1.exe - supports Windows XP SP1.
KB888111xpsp2.exe - supports Windows Xp SP2.
KB888111srvrtm.exe - supports Windows Server 2003 Standard (32-bit version only).
See language list at the bottom of this readme.
These instructions assume that you preinstall the relevant Windows OS over
a network, by using Windows PE.
1. Copy the relevant (OS/Language) install package to a subdirectory on your
technician computer.
For example, create a folder under the OPKTools directory called
Updates. Place the relevan package install file (KB888111xpsp2 for instance) in the
Updates folder.
2. In Setup Manager create or modify an existing Windows
configuration set.
3. Add the following command-line information to the Preinstalled
Applications page in Setup Manager:
Executable: \\server\OpkTools\Updates\KB888111xpsp2.exe (or any of the other KB888111packages)
Parameters: -q -n -z
4. Save the configuration set.
5. Start the destination computer by using Windows PE and preinstall
the relevant Windows OS by using the command factory -winpe.
The UAA HD Audio OOB package is installed immediately after the Windows OS is
installed, and it will be enabled on the next reboot of the computer.
Note: The syntax of the Out Of Band (OOB) installation
program is (example):
KB888111xpsp2.exe [/help] [/quiet] [/passive] [/uninstall] [/norestart] [/integrate] [/forcerestart][/f] [/l] [/n] [/o]
Substitute the file name in the above example with the right package for the operating system you are installing on.
where:
/help Displays a help window with the information below
/quiet Runs in quiet mode, with no user interaction or display
/passive Runs in unattended mode, progress bar only
/uninstall Uninstalls the package.
/norestart Does not restart when installation is complete
/forcerestart Restart after package installation
/integrate:<fullpath> Integrate this software into <fullpath>
/f Forces other programs to close when the computer shuts down.
/l Lists installed Hotfixes or update packages
/n Does not back up files for uninstalling of the package
/o Overwrites OEM files without prompting
