Upravo ovakav sam sebi naručio kao i Nillkin Frosted bamper sa folijom za ekran.Network Technology: GSM / HSPA / EVDO / LTE2G
bands: GSM 850 / 900 / 1800 / 1900 SIM 1 & SIM 23G
bands: HSDPA 850 / 900 / 1900 / 2100 CDMA2000 1xEV-DO & TD-SCDMA4G
bands: LTE band 1(2100), 3(1800), 7(2600), 38(2600), 39(1900), 40(2300), 41(2500)Speed: HSPA, LTE Cat6 300/50 Mbps
GPRS: Yes
EDGE: Yes
Launch: Announced:2016, November
Status: Available. Released 2016, November
Body: Dimensions:155.6 x 77.3 x 7.3 mm (6.13 x 3.04 x 0.29 in)Weight:158 g (5.57 oz)
SIM: Dual SIM (Nano-SIM, dual stand-by)
Display Type: Super AMOLED capacitive touchscreen, 16M colorsSize:5.7 inches (~74.5% screen-to-body ratio)
Resolution:1440 x 2560 pixels (~515 ppi pixel density)
Multitouch: Yes 3D Touch display, Flyme 6.0
Platform OS: Android 6.0 (Marshmallow)
Chipset: Exynos 8890
OctaCPU: Octa-core (4x2.0 GHz Mongoose & 4x1.5 GHz Cortex-A53)GPU: Mali-T880 MP10
Memory Card slot: NoInternal:64 GB, 4 GB RAM
Camera: Primary:12 MP, f/2.0, OIS (4-axis), phase detection & laser autofocus, ten-LED (dual tone) flashFeatures:1/2.9" sensor size, 1.25Video:2160p@30fps, 1080p@30fps
Secondary:5 MP, f/2.0, 1.4
Sound Alert types: Vibration; MP3, WAV ringtonesLoudspeaker: Yes3.5mm jack: Yes 32-bit/192kHz audio, Active noise cancellation with dedicated mic
Comms: WLAN: Wi-Fi 802.11 a/b/g/n/ac, dual-band, Wi-Fi Direct, hotspotBluetooth:4.1, A2DP, LEGPS: Yes, with A-GPS, GLONASS, NFC: Yes, Radio: No, USB:3.1, Type-C 1.0 reversible connector
Features Sensors: Fingerprint (front-mounted), accelerometer, gyro, proximity, compass, heart rate
Messaging: SMS(threaded view), MMS, Email, Push Mail, IMBrowser: HTML5Java: No, Fast battery charging, MP3/WAV/eAAC+/FLAC player, MP4/H.265 player, Document editor, Photo/video editor
Battery Non-removable Li-Ion 3400 mAh battery
Fon bi trebalo da stigne oko polovine meseca pa odmah radim kratak opis.
Na prvu loptu mi je privukao pogled odnosno Samsungov S Amoled ekran extra kvaliteta i to 5.7". Ovaj moj je Asia spec+G PLay, što će reći da na sebi nosi Asia ROM.
Na XDA sam pronašao (baš za njega) tutorijal kako ga rutovati i ubaciti mu Global ROM!!!
O svim detaljima kada fon stigne.
Ostatak Reviewa sledi za 2 nedelje!
