Mechanical Desktop 5 - serial potreban
radar
Hitno.
Hvala.
Evo tebi celo upustvo za instalaciju posto je to malo *******ije nego sto mislis a ako znas jos bolje::D
SINGLE-USER-INSTALLATION:
- start \setup.exe and use following serials:
Serialnumber: 999-12345679
CDKEY: 9XEV61
- start \netsetup\setup.exe , select Autodesk Licensemanager only,
select both (files+tools) and install ADLM
- start ADLM Admin (Programgroup "Autodesk Licensemanager" and enter
following licenses (needs restart after each license):
87705877802508197361733006646307789650738
(feature 160 - AutoCAD 2000i)
33790130491424529394718505922014975362847
(feature 272 - Mechanical Desktop 5)
58928946960557944630612488491501743658813
(feature 273 - Mechanical Desktop 5 PowerPack)
These are network-licenses for unlimited clients !
- start control panel and click on ADLM-symbol
- change start-time to 0 (otherwise it needs 3 minutes to start ADLM
after reboot)
- import mdt5.reg (doubleclick)
Then ACAD searches for networklicenses. You don't need the reg-file
if you do a "normal" network-installation.
- reboot
