info 1:
ELSA MAXtreme is a highly optimized application driver designed to work with 3D Studio applications. ELSA MAXtreme 3D driver enhances the capabilities of the 3D Studio interactive renderer on NVIDIA® based graphics cards.
info 2:
these are cracked MAXtreme drivers that enable the MAXtreme custom 3ds max drivers to be used with any GeForce card.
Normally, in order to be able to use the MAXtreme drivers, you need to have a Quadro card.
Most people SoftQuadro their GeForces into Quadros and then install the MAXtreme drivers, which works fine except that so far no one has been able to successfully make a Quadro 4 out of a GeForce 4. So owners of Ge Force 4's were out of luck.
But not anymore. Now, with these cracked MAXTreme drivers, owners of Ge Force 4's can enjoy the performance boost of MAXtreme in 3ds max without having to shell out cash for a Quadro 4.
To install simply unzip the files into the 3ds max main directory. Then, start 3ds max, go to Customize -> Preferences -> Viewports -> Choose Driver to setup the MAXtreme driver.
Enjoy the speed.
mrzelo me da prevodim
ovi su 'prepravljeni', tako da vam ne treba Quadro niti GeForce kartica ne mora da se 'pretvara' u Quadro sto bi moglo da dovede do pucanja win-a ili igrica (bar se meni to desavalo), znaci samo na nivou drajvera za 3dmax.
download
info 1:
info 2:
Enjoy the speed.
download
